Question about Frigidaire Refrigerators
Why does my Frigidaire model JCD-23 only have power on one side and it won't cool or freeze?
  • Frigidaire Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Posted on Apr 21, 2015
SOURCE: 2003 Frigidaire FRS26BH6CBO Side By Side Problem
DEFROST PROBABLY SET TO AUTOMATIC..NEEDS TO BE REPLACED THEN ALL WILL BE WELL
Posted on Jul 07, 2008
  • 29 Answers
SOURCE: model 57572791 not cooling or freezing on either side
IF YOU LOOK INTO FREEZER BACK WALL CAN YOU SEE HEAVY FUZZY FROST?
Posted on Jan 29, 2009
SOURCE: Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Posted on May 17, 2009
SOURCE: Freezer won't freeze
The system has been stopped due the timer, need to locate the timer and turn clockwise if the compressor start again then you have to change it or look for a short circuit, any case better let the professional make the work
Posted on Jul 08, 2009
heatman101
  • 43501 Answers
SOURCE: frig, not cooling or freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 27, 2010
My Electrolux EW23CS65GS1 model JCD-23 the freezer makes a strange noise at the rear it sounds like it comes from inside what is it and what can I do?
Thanks for your post, Rob Muzich!
From the information you have provided your Electrolux refrigerator is making a strange noise at the rear. Depending on what type of noise you are hearing it could be a normal operating sound. In the manual it provides a list of sounds on page 23. I have included a digital copy of the manual for you to review. If you need any additional assistance please feel free to reconnect. -Matt
Frigidaire Manual Search Results
Nov 28, 2014 | Electrolux Refrigerators
Why doesn't my Frigidaire FRT21TNG freeze or cool fresh section?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRT21TNG, is not freezing or cooling. I also see that the coils are not freezing, the drain line and everything cleaned, and that the capacitor was replaced. From this point, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine why it will not cool as it should. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire refrigerator model ffhs2313lpo
The problem is most likely the=> 241739710 Temperature Control Board That is the electronic display that you said is not working. Sometimes there may be signs that the board is defective but most times there is no physical sign the board is defective, I am here should you need me, Thanks John Tripp Appliance 911
Apr 28, 2014 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
JCD-23 making too little ice
Check the water flow to the ice maker. Turn the supply water off, loosen a fitting near the ice maker and then turn the water on. You should get plenty of water. If it is slow, check the filter.
Dec 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
What stop the compressor, water spilled on the freezer fan though the vent by the ice maker. help
Most likely the=> 5303918476 Defrost Control Board will need to be replaced. This board can be found inside the control panel inside the fresh food compartment. Unplug power and lets examine the board. Here is another source for the board 5303918476 Defrost Control Board Here is a photo of the inside of the control panel HERE and item location 23 is that board. I am here should you have questions, Sea Breeze
Soemtimes the defrost control board will show signs of failure with burn marks and heat damage but not always. It is likely this board is the problem and in some cases the start relay and run capacitor can cause these same symptons.
Jul 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
My refrigerator frigidaire FFUS2613LSO is not cooling
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 23, 2011 | Frigidaire FFUS2613L Side by Side...
Freezer not working nor is the other side
Unplug the Ref for 15-20 min, plug it back in and listen for the compressor to start. You will have to be behind the ref also, check the fan that keeps the compressor cool. If you hear a clicking then the compressor relay is bad. If nothing happens then the defrost timer could be stuck in the defrost mode.
Nov 21, 2008 | Frigidaire FRS26R4A Side by Side...
FREEZER NOT FREEZING
I will be more than happy to help.  Read this first on Frigidaire Refrigerators.   Then if you have anymore questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Jun 30, 2008 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
97 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
