Question about Subaru 2012 Legacy 2.5i Premium
I would like to know where is the 2012 Subaru legacy headlight adjustment screw .
I can't location the headlight adjustment screw .
    New Friend:
  • 169 Answers
Go to auto parts store or google it on the Internet
Posted on Apr 20, 2015
Hi I just bought a pair of low beam headlight bulbs for my 2012 subaru legacy and after coulple hours of struggle i was able to put it on but after that i noticed that my low beam headlights are aiming way...
there should be some long screws in the back of the head light am unsure of what screw is left to right and what screw is up and down though.my advice pull up facing a wall turn ur headlights on and adjust till your happy(once you find out what screw does what of course)
Aug 13, 2013 | Cars & Trucks
How many turn signals does a 1991 subaru legacy have?
No there are just the front bumper ones.
Jun 06, 2012 | 1991 Subaru Legacy
How do you aim or adjust 200l legacy headlights
Hello Terry.
HEADLIGHT AIMING
CAUTION: Turn off the light before adjusting headlight aiming. If the light is necessary to check aiming, do not turn on for more than two minutes .
NOTE:
Before checking the headlight aiming, be sure of the following:
  • The area around the headlight has not sustained any accident, damage or other type of deformation.
  • Vehicle is parked on level ground.
  • The inflation pressure of tires is correct.
  • Vehicle's gas tank is fully charged.
  • Bounce the vehicle several times to normalize the suspension.
  • Make certain that someone is seated in the driver's seat.
  1. Place a cloth over the headlight that does not require aiming adjustment.
  2. Turn the headlights on. Perform the aiming adjustment for the other headlight as follows:
CAUTION: Do not perform lateral headlight aiming adjustment.There you are, the procedure from Subaru manual.
Hope this helps you.
Thank you for using FixYa.
KL
Dec 04, 2010 | 2001 Subaru Legacy
How do you adjust the headlights on a 1995 Subaru Legacy Wagon?
There is no great difficulty in doing this, you can download the procedure from one of my websites here...
[ http://arraw.info/pdf/headlight.pdf ]
Mar 31, 2010 | 1995 Subaru Legacy
How do you adjust the aim of the headlamps on a 2006 subaru legacy
there should be two screws one on top of the headlight and one on the side park the car on a level servise and adjust the headlights till thay are right in front of the car most cars the screew is a filips head
Mar 09, 2010 | 2006 Subaru Legacy
Adjust the headlight beam on 2002 Subaru Outback
two screws on each headlight control the direction the headlights are aimed. One screw, usually at the top but sometimes below the headlight, adjusts the headlight up and down. The other screw, located to one side, controls the headlight from right to left. Turning the appropriate screw one direction or the other will change the direction the headlight points.
In order to aim your headlights you need to have a flat vertical surface you can aim your headlights at in front of a level surface on which to park the car. If your driveway is level your garage door is the perfect place to aim your headlights.
The tools you will need for this job are simple. Masking tape is used to mark where the headlights are to be aimed and a screwdriver is needed to adjust the headlights. A tape measure will be necessary to measure the distance of the vehicle to the surface you're using to check the aim and to measure the up and down distances from your marks
Nov 09, 2009 | 2002 Subaru Outback
Where is the ignition control module located on a 1990 Subaru legacy 2.2l
Center of firewall. It is a black plastic box with 2 screws or e the ignition module could be mounted below the steering column.
Jul 04, 2009 | Subaru Legacy Cars & Trucks
Adjustment of headlights...how to
There is an adjustment screw for the headlight located on the headlight housing. You should just have to turn it clockwise (I believe it requires an allen wrench) and that will raise the light beam higher. If you need further assistance let me know.
Thanks and enjoy,
Lee
Apr 22, 2009 | Subaru Impreza Cars & Trucks
Subaru 2012 Legacy 2.5i Premium Logo
89 people viewed this question
Top Subaru Heating & Cooling Experts
ray gallant
Hank Orsel
Level 1 Expert
Bill Boyd
Are you a Subaru Heating and Cooling Expert? Answer questions, earn points and help others
