I start my pump for the first time but it was no fill with water.it run for about 30 second and cut of .is that a problem
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 169 Answers
You have air in the line have to bleed it out for you have only water in the line forms a vacuum
Posted on Apr 20, 2015
catriver
  • 878 Answers
SOURCE: Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
Posted on Apr 15, 2007
  • 1294 Answers
SOURCE: washer
If your washer does not stop filling, you have a problem with your inlet water valve at the rear top of the machine. You simply have to replace this.
Posted on Dec 02, 2007
  • 24 Answers
SOURCE: neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Posted on Aug 03, 2008
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool washer pours water on right side
The pumps on these washer wear out over time and leak.
While replacing the pump, you should replace the direct drive coupling also. That is part of the torn rubber gasket you are referring to.
This video will show you access to the parts.
Posted on Apr 22, 2009
jumptrout51
  • 3361 Answers
SOURCE: machine fills with water, sits for a couple of
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Posted on Jul 07, 2009
I have a Scotsman CME 506 ice maker. After running a cleaning cycle it won't run. After resetting the freeze light blinks and nothing happens. The water inlet valve never opens (the sump is current
CM3 Operational Sequence.
From Off, push and release the freeze button.
1. If sump is full,water pump starts.If sump is not full,water valve opens to fill it.
2. Compressor starts when sump is full.Air cooled fan motor starts too.
3. water pump stops early in freeze cycle for 30 seconds.
4. Sump refills after pump starts.
5. In low ambient condition,fan motor may begin to cycle on and off.
6. Freeze continues until water level in sump drops to preset point. Exceptions: SCE275 must fill sump two more times.
7. Fan may shut off before the end of freeze.
8. Harvest begins. Hot gas valve opens,pump stops.
9. Pump restarts, inlet water valve opens to fill and overflow the reservoir.
10. Harvest continues for preset first cycle harvest time.
11. If bin is not full, cycle repeats ( compressor stays on). If bin is full, unit shuts off at the end of harvest.
OK with that out of the way unless you unplugged any wires cleaning the machine should not have caused any problems. First cut off water and pull water supply line from water inlet valve look in the end of valve there is a screen in there it could be stopped up. If the valve screen is not stopped up then put supply water line back on and turn water back on. power the CM3 controller off. push freeze button. now with a voltage meter check at the water inlet valve to make sure you are getting power to the valve.If you are then either valve is stopped up or valve is bad. If you are not getting power to valve then replace the CM3 controller now make sure the bin full light is not on because if it is this will not let controller go back to a freeze cycle.
Oct 28, 2014 | Kitchen Appliances - Others
Dishwasher does not function properly
Best way to troubleshoot would be to use a multimeter and measure the electrical voltage at the pump just before the pump is to activate, watch the multimeter display for a drop in electrical voltage, if it does drop to zero the electronic control board located within the door has failed.
Dec 22, 2013 | KitchenAid Dishwashers
Bosch Dishwasher has started acting upo. If I turn on the dishwasher it runs the pump for approx 2 seconds then cuts out. This carries on the cycle spraying the soapy suds around the compartment but there...
Most dishwashers pump out briefly before filling in order to clear pressure chamber. The next step is the water fill which is monitored by the pressure/level switch. Once water level is attained timer will advance through cold rinse cycle. If no fill is happening, would suspect inlet valve faulty in the first instance.
Apr 02, 2011 | Dishwashers
The engine cut out then right away was running again then 20-30 seconds later completly cut out again. After a few minutes it started again and ran for another two days. Then it cut out again, ran for...
- When was the last time this car had a tune-up? Could be as simple as that. New spark plugs/rotor/distributor cap/condenser might do the trick.
Other causes could be:
- bad fuel pump relay (definitely first on the list of things to check, and cheapest to fix)
- clogged/old fuel filter
- bad fuel pump
Mar 01, 2011 | 1991 Honda Civic
I AM RESTORING A T020 MF. I REPLACED ALL WIRING AND IGNITION SYSTEM AND REBUILT THE CARBURATOR, AND ADJUSTED IT TO SPECS. I GOT IT TO START RIGHT AWAY AND IT SOUNDS GREAT. HOWEVER, IT WILL ONLY RUN FOR...
Ok a quick check. When the engine cuts out and you go for restart it dies within 5 seconds. Next time put the ignition at position 2 (on but not starting) and wait one minute, then start the car. If the engine again runs for 30 seconds before cutting off this tells you its is a fuel problem. If the fuel is supplied slowly it fills the carburettor fuel bowls and when the car starts it quickly uses up these local reservoirs of fuel faster than they can be replenished. When you try to restart immediately there is only a tiny amount of fuel and so it used up almost immediately. By leaving the ignition on 2 for while it gives the pump time to fill the carburettor bowls and this takes a while longer to run down when the engine starts. Just before moving on does the car have a choke OK remove the low tension connection to the coil, basically remove any chance of a spark. Put a big old towel around the carb. Now remove the fuel line at the carburettor and put ignition on 2 to engage the starter pump. Listen to pump operation and look at the rate of fuel being pushed from the disconnected fuel pipe. If the flow is slow check on pump and filters.
Sep 13, 2010 | Ford F-100 Cars & Trucks
I turn on the top load washer ,it starts to fill
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 13, 2009 | Kenmore Washing Machines
Polo 1.4 cutting out every 30 seconds
Do you hear the fuel pump cut off? Once your pump reaches pressure it should cut off. Also you can try and remove your fuel cap and see if the car will run just know it could cause your check engine light to come on so do not run it very long. If it continues to run with fuel cap off I would say it is your fuel pump. Good luck with that and the best thing to do is get a fuel pressure gadge and see what kind of fuel pressure you are running. I know there are some parts houses that will loan or rent you tools. Good luck.
May 24, 2009 | 1994 Volkswagen Jetta
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Apr 22, 2009 | Whirlpool Washing Machines
G 892 intake light on
Reset the program by holding down the start button. It will be blinking. Then try the same wash selection and start it. If you wired correctly the drain pump will run 30 seconds. If the intake light comes on in 5 seconds and the drain pump is still running then you have a leak. Miele dishwashers have a safety system that catches water and triggers the alert. Ifthis is the case, there's nothing you can do but get a repair person to pull the machine out and find the leak. If the pump does drain only 30 seconds, then it will stop the pump and let water in. If it fills okay then it will circulate the water and if you haven't oversudsed it [ Energy Star machines use much less water and therefore make much more suds if you fill up the dispenser too high with detergent ] the suds will not trip the pressure switch. Otherwise it will start to heat the water. If the intake light comes on again it's important to know when it does. The computer inside evaluates 100's of steps. The Techs at Miele will need to run it with you on the phone. They have scripted access to the electronic memory and you participate to find the information. They can determine if you can fix it or not.
Apr 15, 2009 | Miele 24 in. G892SCU Plus Built-in...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
