Question about Sewing Machines
Double needle keeps breaking - Sewing Machines
  • Sewing Machines Master
  • 1,860 Answers
The needle is incorrectly inserted
the needle clamp screw is loose
the threads were not drawn to the rear of the machine after sewing
the needle is too fine for the fabric being used
Posted on Jun 03, 2015
2 Suggested Answers
  • 9 Answers
SOURCE: Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Posted on Jun 12, 2009
Why does the thread on my sewing machine keep breaking?
Several possibilities. It could be the needle, the tension too tight, mis-threading, the thread weight, brand, poor quality, or fabric incompatibility with needle & thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Does My Thread Keep Breaking While Sew
All About Needles
Nov 09, 2016 | Sewing Machines
How do i change double needles on janome mylock
Don't know the model of your machine but this manual, or one specifically for your machine, may be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwio3tC-1p7PAhXm5oMKHed8DIMQFggeMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Fsergers%2Finst-book-634d.pdf&usg=AFQjCNFFa0YXjvhgmGspP4BP7E6p_z59bA&cad=rja
FWIW, overlockers do not take double needles. There are usually at least two needles each installed separately. If you try using a double needle, you will most likely break them and possibly damage you machine.
Sep 20, 2016 | Janome Sewing Machines
Why does the right needle keep breaking in myloc 634d
I agree with John Smeed It could be that the needle is bent or in the wrong way if it keeps on breaking it must be hitting the throat plate or it's timing may be out( a pro job) Also check the needle is in as high as it can go.
Apr 19, 2014 | Janome MyLock 634D Mechanical Sewing...
Have a Janome 1600P-Top thread keeps breaking
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Apr 21, 2013 | Sewing Machines
My machine keeps breaking the thread
Mar 02, 2013 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
Oct 08, 2012 | Juki Sewing Machines
I have a Juki DDL 227. Top thread keeps breaking instantly
Well, you've not checked "Everything" but you have checked the common things.
Do you have any idea of where it is actually breaking? Re-thread your machine and see if you can determine exactly where the break occurs.
Sometimes a damaged needle throat plate will break threads... as will a burr on the hook in the bobbin area. Also if there is a burr or rough spot on the thread spool it will sometimes catch and cause breakage.
Good luck
Jul 23, 2012 | Juki Sewing Machines
THE DISNEY PICTURES EMBROIDERED SEEM OUT OF LINE WHY IS THIS & IT KEEPS BREAKING NEEDLES ITS A BROTHER PE-180D EMBROIDERY MACHINE CAN ANYONE HELP ME????
Use cut away stabilizer and if you are already doing this, double the layer.
The needles may be breaking because they are too small or not installed correctly.
Try a size 14 machine embroidery needle and check the manual to see if this is with the flat side of the needle to the back of the machine.
One other thing could be that the timing needs to be adjusted. You can find information on how to set the timing at sewusa.com or take the machine to a professional for service - always take an example when the machine has been mis-stitching.
Mar 01, 2010 | Brother Sewing Machines
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Aug 11, 2008 | Sewing Machines
Sewing Machines Logo
43 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
