Question about Refrigerators
Can you please tell me what the inside top fan is called on my Mt 12 cooler. also the door is sagging a bit.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 169 Answers
Call the manufacture ask for tech support they will tell you the fan and part number sag in door hinges need to be adjusted on door
Posted on Apr 20, 2015
The top door is frosting on the inside, changed the gasket same problem. It seems the door is sagging down a bit.
You might try loosening the screws on the hinge on top of your refrigerator and then lift up on the corner of the door away from the hinges and then re-tighten the screws. That will help put your door back in alignment and hopefully end your frosting. Hope this helps!
Jan 20, 2015 | Hotpoint HTS18 Top Freezer Refrigerator
How can I fix a sagging screen door?
any hardware store sells an anti-sag kit. It is a rod with a turnbuckle. A Heavier door can require 2, One inside and one out side
Oct 10, 2014 | Superior Alhambra Wooden Screen Door 36" -...
Overheating yamaha mt03 coolant temperature sensor too late?
Hi, Anonymous and the usual suspects are:
1. Engine oil level and SAE weight are too low or not circulating.
2. Insufficient or blocked air flow over the engine.
3. Heavy combustion chamber carbon deposits.
4. Ignition timing retarded due to faulty MAP, CKP, or CMP sensor.
5. Carburetor jetted too lean.
6. Leaking intake or exhaust valve.
7. Water coolant old or low change every two years.
8. Water pump failure.
9. Radiator clogged, cap loose or malfunctioning.
10. Radiator fans not coming on.
11. Clutch slipping, brakes dragging, heavy load, towing a trailer etc.
12. Idling too long without moving.
13. For constant hot weather temperatures, mountain, or desert riding conditions consider adding an oil cooler and or cylinder head cooler.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Symptoms of Bad or Failing Coolant Temperature Switch Sensor YourMechanic...
http://www.mt-owners-club.org/forum/viewtopic.php?t=10251
Yamaha MT 03 Service Manual
OEM parts for Yamaha
YAMAHA MT 03 Owner Manual
Mar 21, 2014 | 2008 Yamaha MT-03
I have a True Cooler GDM-35SL-RF. the fans are not working but the compressor is. What can I do to fix this and where on the cooler would I find the problem?
They have a support line here:
http://www.truemfg.com/24HourTech_en.aspx?language_id=1&event_id=401&from=food
Our Technical Service department is available via Internet or phone
Monday - Friday 7:30 AM - 5:30 PM CST and on Saturday 8:00 AM - 12:00 PM CST.
Via phone please call 1-800-325-6152 and ask for the Service Department
You can also use the page to ask any questions. I suspect you have a fan relay that has failed as the fans should be running anytime the compressor is running. Since all of the fans are not running that leads me to think it is a relay problem.
One thing to need to make sure is to verify that all fans.. condenser (bottom of the unit) and evaporator (inside the unit) fans are not running. If the condenser fan bottom of the unit is running and the evaportar fans are not running it could be something as simple as a door switch that has failed. Call them during business hours and I am sure they will tell you what the remedy is.... and of course.. do their very best to ensure they get to send a repair tech your way.
Thanks for choosing FixYa,
Kelly
Sep 04, 2011 | True 72 cu. ft. / 2039 liter Commercial...
My mt 12 cooler doesnt blow cold just warm air
thermostat could not be set properly, compressor could not be running, unit could be low on freon. start checking some items and let me know.
Aug 03, 2009 | Carrier Beverage Air® Marketeer® MT12-1-B...
Fan runs all the time
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
Apr 01, 2009 | Beverage-Air MT17 Refrigerator Commercial
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
How long for continental double door cooler to cool, once plugged in?
Fans inside should run steady for proper operation of the cooling system. Since you used the term fans I would think you have an open circuit to the fan motors. It may be something as simple as the cord for the fan power is unplugged. This plug would be located under the evaporator cover.
Sep 11, 2007 | Continental 1RX Refrigerator Commercial
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
