Question about Kitchen Ranges
Door was locked accidently while cleaning and will not unlock. cannot start a self clean cycle to try to reset and have tried press the light for 20 sec. nothing seems to work.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
Go to repairclinic.com and you may find your answer there. I use it all the time.. You will need the model number when you go to the site. If you can't find it there put the info here and I will try to help ya. Also, try to unplug it for a few minutes, may reset it. Good Luck.
Posted on Apr 20, 2015
What does error code F-90 mean on a Kenmore delf cleaning wall oven
The F90 error code indicates that the door unlock time exceeded. This will happen if the lock is in the locked position with the oven door open or if the lock motor fails. Have someone hold in the oven door light switch while you set the control up for the self-cleaning cycle. Let the self-cleaning cycle run for only 4-5 minutes then press stop/cancel. This should allow the lock assembly to reset & retract the door lock back into the unlocked position.
You can also try resetting the appliance by disconnecting it from the outlet or switch off the circuit breaker for 20-30 minutes. Once power is restored run a test cycle. If this does not work I suspect a door lock assembly failure. This type of diagnosing will require accessing the lock assembly & using a volt/ohm meter for testing
Nov 03, 2016 | Kenmore Ovens
"Locked Door" flashes after interrupting self clean...
Hi robertkbrown...you may want to try to following steps.....good luck my friend...chris If ?LOC DOOR? is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control: Motorized Switch 1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel. 2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed. 3. While you hold the door jamb switch in this position, complete the following steps. 4. Press the Clean pad, wait 10 seconds. 5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it. 6. Wait 10 seconds for the display to clear. 7. The door should unlock and there should not be a need for service. Manual Switch 1. Press the Clean pad. 2. Close the door. 3. Slide the latch to lock the door. 4. Hit the cancel button immediately. 5. Unlock the door.
Aug 25, 2007 | GE JBP60 Electric Kitchen Range
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
Did the self clean and now the oven door will not unlock
Hi
Door is not unlocking as the control has detected a problem with door latch switch or the cycle was interupted in between. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether you are able to unlock the door. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. Please post back for any further assistance...
Daniel
Aug 28, 2010 | Kenmore Kitchen Ranges
Self cleaning issues
this may be as simple as pushing in the door/light switch
1. select a clean cycle and start it
2. aftewr you press start, locate the oven light switch (should be somewhere that the door can hit is so light will turn on and off as you open and close the door) keeping the switch pushed in, press the cancel button to cancel the cleaning cycle. the door lock mechanism should then unlock
let me know how this does
May 01, 2009 | Kitchen Ranges
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
Oven Door Locked
Try resetting theclean cycle. Hold the door handle a little ajar. It won't open of course so reset the clean cycle then press cancel.  This may do the trick
May 04, 2007 | GE JBP82 Electric Kitchen Range
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
