Question about Orbit Hardware & Accessories
Orbit says OFF will not turn on...no other power symptoms
Model# 57874
Copy following links to identify timer manual and general wiring illustration:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
http://waterheatertimer.org/images/orbit-connections.jpg
Do not connect voltage directly to COM and Pump terminals... these terminals have their own 24Volt AC output when timer turns ON. When timer turns on, the 24V flows to Relay. This action will cause electro-magnet to pull two points together, and that will turn on the pump.
Same with the sensor terminals. Do not connect power to rain sensor terminals. The rain sensor plugs into outlet, and produces it's own 24V ac output. So when rain sensor activates, this cuts power to timer, and then timer will automatically bypass the watering schedule until rain sensor again resumes power output to timer.
Gene
Jul 25, 2013 | Orbit Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I have an Orbit WaterMaster Sprinkler control, it is hooked up, but there is a light bulb that says power off and the sprinklers won't turn on. They will turn on manually at the sprinkler station. Can...
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Apr 11, 2010 | Orbit Sprinkler System Power Source...
No power to xda orbitI tried to turn it on but nothing at all,it was'nt charge also.I chargemy orbit battery from external charger,then put it back in (orbit) cellphone,still no power to my vda orbit, I...
Hello, if you have already tried loading the ROM from the SD Card (presumably you did download the NBH file of the ROM to the SD card first??!) then your phone cannot be repaired software-only - it will probably need hardware replacing or repairing - it would most likely be more cost effective to buy a new phone and sell your old one on eBay for spares.
Nov 22, 2008 | O2 Xda Orbit Smartphone
No power to xda orbit I tried to turn it on but nothing at all,it was'nt charge also.I charge my orbit battery from external charger,then put it back in (orbit) cell phone,still no power to my vda orbit,
I also tried theas steps on it.eg: press voice recorder button+power button and then press and hold restart button for 10 sec...this shortcut for going to bootloader and restore orignal rom from sd card (image).but it's not work,still no power to my vda orbit, pls help me.I'll be thankful 2 u,
my e-mail id ahtsham@ymail.com
May 02, 2008 | Computers & Internet
O2 orbit will not charge or turn on just red light
Anyone have a solution to this problem? I have the same thing! please e-mail: mynewemailaddie@yahoo.co.uk
Thanks.
Mar 13, 2008 | O2 Xda Orbit Smartphone
Hardware & Accessories Logo
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
