Question about Orbit Hardware & Accessories
Orbit will not turn on - Orbit Hardware & Accessories
How long dose Saturn take to orbit the sun
Saturn orbits the Sun further away than Earth. And because of this, the orbit of Saturn takes much longer than the orbit of Earth. How much longer? It takes Saturn 29.45 years (or 10,759 days) to orbit the Sun. Astronomers call the length of time an object takes to go around the Sun its orbital period. So the orbital period of Saturn is 29.45 years.
Mar 12, 2015 | Optics
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Cant seem to get the saw to rotate have a 12 amp orbital saw zall
if by rotate you mean the orbital action, could be a couple problems. first there is a pin inside the gearcase that rides on an eccentric shaft that one or both could be worn not allowing this. Also the lever mechanism that turns for the orbital might not be rotating fully. I would suggest before attempting anything that you go to Milwaukeetools.com and under parts/service download the breakdown so that you can see what you are getting into. DO NOT remove the retaining ring that holds the orbit pocket assembly into the gearcase, it requires a special service fixture to reinstall and it is no fun. Let me know if you need more assistance and I will try and help. Thanks
Feb 11, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
No power to xda orbit
No power to xda orbit I tried to turn it on but nothing at all,it was'nt charge also.I charge my orbit battery from external charger,then put it back in (orbit) cell phone,still no power to my vda orbit,
I also tried theas steps on it.eg: press voice recorder button+power button and then press and hold restart button for 10 sec...this shortcut for going to bootloader and restore orignal rom from sd card (image).but it's not work,still no power to my vda orbit, pls help me.I'll be thankful 2 u,
my e-mail id ahtsham@ymail.com
May 02, 2008 | Computers & Internet
O2 orbit will not charge or turn on just red light
Anyone have a solution to this problem? I have the same thing! please e-mail: mynewemailaddie@yahoo.co.uk
Thanks.
Mar 13, 2008 | O2 Xda Orbit Smartphone
XDA Orbit Help
you need to hard reset your PDA and need to reinstall the OS..this will help you
all the best
Jan 06, 2008 | O2 Xda Orbit Smartphone
Hardware & Accessories Logo
101 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
Hippy_dd
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
