Question about Tablets & eReaders
My tablet will not come on it goes from the first page logo for trio to where it says@9dual core logo then won't go anymore ?
  • Tablets & eR... Master
  • 5,631 Answers
If your tablet is on warranty, return it to shop. This kind of failure indicated tablet is not working and I see no way any user might get it working.
Posted on Apr 20, 2015
3 Suggested Answers
  • 9 Answers
SOURCE: I do not have a internet connection on my tablet
I wish ur tab does't hav cellular data conection or its not supporting.
Posted on Jun 18, 2014
mushtaq_maho
  • 46 Answers
SOURCE: I have a trio Stealth-10 tablet and when i turn it
you have malware or virus best suggestion is to reset it to factory default assuming it has an android operting system
Posted on Jul 16, 2014
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Jan 01, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
My trio stealth is new. When I power it on, goes to a screen "@9dual core" and doesn't go any further. Help!
There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also work, I've learned, on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned. But.... TRY AT YOUR OWN RISK. Here it is.
(1) PRESS AND HOLD the power button until the tablet shuts off completely.
(NOTE:
if any type of start-up screen comes on, FORGET it: the Tablet must be COMPLETELY powered off for this to have any chance of working.)
(2) PRESS AND HOLD the volume-down button, while simultaneously PRESSING AND HOLDING the power button
This will (hopefully) bring up the Android figurine, along with some kind of rotating-wheel graphic.
(3) Do nothing else but WAIT, until the screen changes to a text-based menu, with about 6 to 8, or more choices.
(4) Use the volume-up and volume-down buttons to navigate between choices, and select (highlight) the choice offering to reset the tablet (to Factory Settings).
(5) Click and release the power button to start the reset operation. Follow and additional prompts to ensure you are selecting the correct next step.
This RESET process will erase ALL your installed apps, as well as delete all your saved photos, music and other user files and preferences (including wallpaper, time-zones, Wi-Fi settings etc. But when it works it will give you back a working Trio. Use your reset Triot carefully: generally, I'll say the Trio machines are good economical alternatives to the perhaps more robustly engineered (and much more expensive) big brand items.
Regarding restoring personal preferences, and earlier installed apps I have no experience whatsoever. However there may be sufficient arguments to backup your personal data either on your home computer or on online "cloud based" services. Do the research, ok?
Happy New Year, 2015 ... & ....Good Luck!
Dec 28, 2014 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
I have a Trio-Stealth G2-8 and turn on but the screen said @9 Dual Core and don't do anything else can somebody tell me how to fixed?
Its a common problem with tablets and not easy to fix.
Your tablet has a corrupt os and is caught in a boot loop.
There are fixes but not easy for a beginner.
Boot into recovery mode by pressing the power button and holding the down volume button in then select restore tablet from the recovery menu.
Jun 12, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
Apr 24, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Trio tablet screen stuck on trio logo
hi try doing it this way.all data will be lost...
Jul 07, 2017 | Tablets & eReaders
Trio stealth-8
I fixed this triple screen issue by opening the unit (2 screws, then slide fingernail around the edge), then reseat the video connector (it's the largest connector), flip up the locking tab, then reseat the connector & flip the tab back down. Test it, then close it up.
Jan 19, 2014 | Tablets & eReaders
Machspeed Trio DROID-7C 2.3 4GB Tablet
Im sorry to hear that. there are some things u can try and sometimes it works but i have been doing this for long time. and i wont tell you to return it and get another or refund. so here u go
Sep 27, 2012 | Machspeed Trio DROID-7C Tablet
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
