Question about Cub Cadet Garden
How do I change the engine oil on my Cub Cadet DE Lawn Edger ?
Is there a Drain Plug ?
    Top Expert:
  • Cub Cadet Master
  • 43,095 Answers
Yes check either side of the block . possibly under neath too
Posted on Apr 20, 2015
Engine is smoking on Cub Cadet LE-100 edger. Is it because of old oil, and if so, howdy I empty the old oil?
Sounds like the rings are leaking. Changing oil will help. look on engine crankcase and see if there a screw type plug the bottom of plug should be facing down. Look in yellow pages and find a repair shop and ask them how much to repair. Sometimes it may cheaper to buy new unit
Jul 02, 2017 | Cub Cadet Garden
Location of oil drain plug
If this is the same as my Craftsman, it is very convenient, but sneaky.
There is a hose attached to the side of the engine. To drain the oil, unclip it, open the top, and then lower it indo your dirty oil collector. If it does not have this gizmo, there will be a drain plug near the lower edge of the engine.
Sep 14, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Self propelled cadet mower locked up how to unlock
Check engine oil level first for proper level.If it has oil in it PULL SPARK PLUG WIRE OFF SPARK PLUG IF MORE THAN A SINGLE CYLINDER PULL ALL PLUG WIRES OFF. Put unit on its side and grab the blade and see if you can move it in either direction or if the engine is locked up.
Jun 11, 2014 | Cub Cadet Lawn Mower Deck Drive Belt...
Where is the oil drain port on a cub cadet push mower
On right of motor towards the bottom of engine. Be a plug or valve
to turn.
Mar 03, 2013 | Garden
I have a cub cadet with a kohler command series 16 engine..It runs rough,oil gets on the spark plug and smokes a little what is wrong with it?
This usually means that is's been overfilled with oil, or the engine has been tipped enough for oil to run into the cylinder. Drain oil if it's above the line at all, and the problem will go away once the oil's burned out of the cylinder.
Mar 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub zt commercial mower (Kawazaki engine) will not turn over after oil change
take the spark plug out and try turning it over it may have too much gas in the cylinder our to much oil in the block
Jun 26, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Jun 12, 2009 | Garden
Lots of smoke coming out of Cub Cadet 2146 muffler
Check the dip stick to see if you over filled it.. You shouldn't have oil above the top line... If you did over fill it remove the dip stick and tilt the mower to the exhaust side to drain on the excess oil out of the dip stick tube...
If it's not over filled with oil the engine more then likely shot and it's time for a new mower..
May 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
57 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
