Error code E8 always appear then the aircon automatically shut down
    New Friend:
Write your answer...e8 my problem
Posted on Mar 25, 2016
  • 391 Answers
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. I can help if you provide this information.
Air Bulance AC Cleaning Repair Services
Posted on Apr 27, 2015
2 Suggested Answers
SOURCE: Panasonic reverse cycle aircon.
Found the codes are printed inside the air conditioner.
F33 ---01. = locked up compressor.
Cannot fix this problem myself, will have to engage a serviceman.
Posted on Jul 17, 2008
Where is the distributary valve?
that is a very good question
i cant find a "distributary valve" for sale
lots of water inlet valves hot and cold single units
almost every dishwasher user manual and has code e8 mentioned and faulty distributary valve
why the fault
.If the distributary valve have worked for 150
seconds, and could not reach right
position during wash cycle,after the cycle is finished, the dishwasher will shut off all
loads, the alarm buzzer will ring for 30 seconds and the window will display "E8" at rate
of 1Hz in 30 seconds, and then display "E8" , drain water for 2 minutes meanwhile
May 12, 2016 | Dishwashers
Panasonic cs e9nkr aircon. Shuts down timer continuously blinks. Checked for fault codes h00
I haven't got the service manual for this but the error codes should be on a sticker behind the front cover. Take that of and it will guide you to the fault.
Feb 19, 2015 | Panasonic Heating & Cooling
Pls help me to fix my aircon there is error E1
E1 Code validation check fail / shut down the unit and restart.
see more Air Conditioning Fault Codes
Jul 04, 2014 | Heating & Cooling
Why E2 error appears and aircon shuts down?.
Seeing as this is the CAR AND TRUCK section, home appliances are just not my forte. Sorry I can't help.
May 08, 2014 | Cars & Trucks
Code E8 on NS30LE how to fix this
An "E8" message appears on the panel.
Description: You tried to select a different stitch while the twin needle sewing setting was selected (the key is lit).
Select an appropriate stitch, or use the single needle sewing.
Note Each time a key pressed or an incorrect operation is performed, a beep is sounded.
  • For a correct operationOne beep is sounded.
  • If an incorrect operation is performedTwo or four beeps are sounded.
  • If the machine locks up, for example, because the thread is tangledThe sewing machine continues to beep for four seconds.
    The machine automatically stops.
    Be sure to check for the cause of the error, and correct it before continuing to sew
Jan 09, 2014 | Brother Sewing Machines
What is E4 error code o. Yonan airconditioner?
My yo nan midwall split aircon is displaying an E8 error code. What is the fault?
Aug 12, 2013 | Heating & Cooling
A error code E154 appears, then I shut down the unit, and restart, no problem a few minutes, then the error code appears again. have you the solution?
Hello there, I guess your Running capacitor is leaking already, when you start your aircon it will run after a minute the aircon will stop with errors, because the fan is stop running due to busted capacitor. thanks
Apr 25, 2011 | Heating & Cooling
When on camera E8 will appear
Error Code E8 is due to a Motor and Sensor Issue within the Optical
Sep 05, 2009 | Canon PowerShot SD100 / IXUS II Digital...
Canon mp150 error code E8 does this mean that the printer is useless even though we have cleaned the ink pads?
Re ; Canon MP150 printer error "E8".
We found a blog that explained that once this error appears, even if you clean the ink pads as we did you cannot erase the error message. Therefore unless you pay a call out fee, not worth it in comparison with a replacement printer, the printer is of no further use. An "extermination" code it would appear!
Jul 22, 2008 | Office Equipment & Supplies
Jul 15, 2008 | Heating & Cooling
Heating & Cooling Logo
614 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
