Question about Dyson DC21 Motorized Power Floor Tool
Powerhead on vacuum shuts off after about 5-10 seconds of use. What is cause?
Powerhead keeps shutting off. I cleaned the beater bar, filters, and it still shuts off. It even shuts off while holding in my hand and off the floor, not even doing any vacuuming. The electrical contacts seem a bit loose (they flex up and down a bit in the unit) could that be the problem?
    Master:
  • Dyson Master
  • 403 Answers
There are several possibilities, some of which you seem to have already checked.
1) The filters are clogged. System will cut out quickly if there is little or no airflow, to prevent overheating.
2) There is a clog somewhere besides the filter. Run through the checking for clogs steps in the manual, page 6. (
https://www.dyson.com/parts/u/user-guide/medialibrary/9118C278B029492DA662A45A70F187B0.ashx )
3) There is a small, Hall-Effect sensor near the filter that detects that the filter is in place and seated properly. If it is faulty, or the filter ISN'T seated properly, it cuts the power. Replacing that is beyond the scope of what I can safely advise on.
4) There are temperature sensors for the unit. If it's too cold, or too hot, no power. Too hot means the system thinks the battery is overheating, which can be dangerous. If the temp sensor is bad, that could do it too. This is also past what I can really help you on.
Good Luck!
Posted on Nov 04, 2015
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Posted on Jan 01, 2009
Vac Belts
  • 701 Answers
SOURCE: When switching the vacuum (DC17 Animal) over to
The drive belt has probably broken. You can get a replacement belt here:
Dyson DC17 Belt
Posted on Dec 05, 2009
  • 389 Answers
SOURCE: The beater bar seems to have worn and is loose.
Not sure how I can help, as it seems you know what the problem is! Fit a new brush bar! On some Dyson models (not sure if the DC17 is one of them) you have to fit a new sole plate at the same time - they are supplied together as a kit. Good luck.
Posted on Jan 02, 2010
Vac Belts
  • 701 Answers
SOURCE: DC 17 Beater Brush won't turn
You need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Dyson DC17 Belt and Manual
Posted on Feb 07, 2010
  • 66 Answers
SOURCE: Vacuum will run for 5 minutes and shut off,
Your Dyson is designed to cut out if it becomes overheated, and it then takes about half an hour to cool down properly. If you don't resolve the problem, it will soon cutout again. Clogeed filters or other blockages are the usual cause of cutting out, but there are others, for example, incorrectly fitting valves, or broken belt. You need to do more cleaning. Follow the step by step instructions for your model, which can be found here.
http://www.dyson.co.uk/support/help.asp?article=51&product=DC07-ANIMAL
You will be following a path for solving cutting out when you are using the machine, and I would be surprised if you can't fix yours.
Posted on Jul 10, 2010
The beater bar works but the vacuum canister shuts off after a few minutes. Then the switch will only turn the beater bar on and off.
You may have a thermal reset in the vacuum motor that shuts the motor off if it gets hot. Clean the vacuum and replace the filters.
Feb 28, 2016 | Vacuums
My powerhead shuts off after about 15 seconds of running. It will turn on again after a brief rest. What could be causing this?
sounds like it's overheating and tripping the breaker. When it shuts down try pressing the little red breaker button. Could be a restriction of the rotating brush or a short in the extension connector. Remove the bottom plate and visually check for a cord or string wound up in the rotating brush mechanism and check the extension tube and flex tube for obstructions... Try the head without the wand by just connecting it directly to the flex tube and see if this makes it work without shutting off. I'm betting on something binding the roller brush and causing it to overheat...
Apr 11, 2015 | Filter Queen Majestic Canister Vacuum
Beater bar not turning
The number one cause of the "beater bar" (or brush roller) not rotating is a broken belt.
The number two cause of brushes not rotating is that something is jammed & wound around the roller, preventing it from rotating.
For the belt: If you remove the screws holding the bottom plate, you should see one (or maybe two) short, wide rubber belt(s) that goes around the roller.
If this is broken, it's easy to replace. They do break because of age and wear. One of the leading causes of breakage is when the roller gets something - a curtain cord, for example - wrapped around it. If you don't immediately shut off the vacuum & remove the cord, the belt will continue to try to turn the roller (which can't turn), and this generates a lot of heat in just a few seconds.
You can find belts at places like Sears, Home Depot, or your local vacuum shop.
For just the roller: Turn the vacuum over on its side and inspect the roller. Will it turn? Can you see something wound around it that's jamming it? While you here, take a minute and clean the roller... including using scissors or a knife to snip & remove wound hairs & threads. A clean and healthy roller will help to keep your belt happy!
Mar 03, 2011 | Cirrus CR99 Bagged Upright Vacuum
My dyson animal works for a while then shuts off...i guess it's getting hot and automatically turning off to keep damage from occuring. i have cleaned the filter and all the collection basket, but am still...
The belt that drives the beater bar may be broken or stretched, causing the motor to turn more freely, therefore causing the motor to rev beyond it's design.
Jim
Dec 03, 2009 | Vacuums
Beater bar
There may be a shutoff switch, located on the hood, that shuts off the agitator to permit bare floor cleaning. Return the switch to carpet mode.
Sep 29, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Power head turns on and off as the unit is vacuuming
Probably not hose but more then likely is a problem within your wand. Try connecting your hose handle directly to your powerhead and see if you can get consisten power. I work in customer service for electrolux and more then likely it is in fact the wand
Jul 17, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Beater bar not working on Halo vacuum
Check the bar to see if there is a buildup of hair or string causing it to jam,
Jun 17, 2009 | Vacuums
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Dyson DC21 Motorized Power Floor Tool Logo
370 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
