Question about Soleus LX-140 Portable Air Conditioner
E3 code displayed and unit seems to be running but no air flow. after turning off unit for a minute or two it will operate properly for a while and then the e3 code will come on and repeat the cycle
    Novelist:
    Champion:
  • 373 Answers
Yes check filter first, but also check the condenser coil and clean this should be done at least once a year as preventative maintenance. also make sure the condenser fan is running. E3 is a faulty coils code.
Posted on Apr 20, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 169 Answers
Check the filter on the back of unit maybe dirty needs cleaning
Fh code when filling but it has water coming into the machine
see this causes and fix it. God bless you
FH No water detected entering machine or pressure switch trip not detected If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.
Oct 11, 2012 | Washing Machines
FH code
FH: If after 30 seconds the control does not detect water entering
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
pressure switch, drain pump, flow meter, and
Sep 22, 2011 | Whirlpool Washing Machines
The e3 light is on and its not cooling just fanning
The E3 error code, indicates that the water in the collection tank is full and needs to be emptied.
Turn the unit OFF & unplug it, before attempting to drain the tank. Once that is completed, the unit should operate as designed.
Hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | Royal Sovereign ARP-4010 Air Conditioner
Code F & H popped up
on all the way.
the inlet valves.
VERIFY PUMP OPERATION
Duet washer service manual and more HERE
Feb 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code 'FH' flashing - washing machine is fillling up, washing but not draining. We have removed and cleaned pump and checked waste pipe is clear.
on all the way.
the inlet valves.
Dec 28, 2010 | Washing Machines
I have the machine on normal cycle and I get an F20 code and no action from the machine. If i push the pause botton the machine sounds like it is running but nothing else is happening.Action ends after a...
The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
The possible fix for this problem is:
If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way.
If there is water in the unit: Verify that the pressure switch hose is in good condition and
1. Unplug washer or disconnect power.
2. Verify there is not a siphon problem.
3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
Thank you
Aug 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My wash machine is blinking F and H when I try to start it..what is this..i checked all connections of water..seems to be connected. hmm? help?
OR
Aug 05, 2009 | Kenmore Washing Machines
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
F h code on duet
FH= No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then
Or
If the control has turned the water valves on and after 8 minutes the flow meter has
Potential Causes
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Apr 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Tub won't fill
hi there,
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Verify CCU operation.
best of luck....
Feb 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Soleus LX-140 Portable Air Conditioner Logo
821 people viewed this question
Top Soleus Heating & Cooling Experts
Coss
Dennis Boxerman
Harjeet Singh
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
