Question about Grohe rohe Grohmix Integrated Thermostat Valve And Trim 34436000-GH 9 1/2
Can't turn valve to adjust hot and cold. Valve about 12 years old now. What can I do?
    Top Expert:
  • Grohe Master
  • 50,269 Answers
Try oiling it with wd 40 then plan on replacing it
Posted on Apr 20, 2015
    Director Badge:
    Uploaded 100 video answers.
  • 96 Answers
Needs dismantling and cleaning. See this
Posted on Oct 29, 2015
What is the valve settings
If you have adjustable tappets the setting are usually .010" hot inlet and .12" hot exhaust. Start at 12 and 14 cold and recheck when hot. If you have hydraulic tappets there is no adjustment as they automatically adjust when oil pressure is achieved
Jan 26, 2013 | Cars & Trucks
What are the valve clearances for a 2e 12 valve engine?
I have Toyota Corolla EE80 2E engine with 12 valves. I recently top overhaul but the engine is not running in perfect condition. The engine rpm goes up and down (engine shaky). I set the rpm around 1200, if i set it lower than that the engine will stop. I check the engine timing with both the cam and crank on the correct mark. Sounds like the carburetor failure but i had service it but still the same. If i turn the distributor to the right (******) the engine rpm drop, than i turn it to the left (advance) but the rpm drop too, as i know the engine rpm should raise high and could hear the pinking sound from the valves if the the engine accelerate. For your info, i bought the cylinder head from someone who previously general overhaul his engine about 6 months ago. He dismantle his engine because of con rod problem. I just fix the cylinder head to my engine without grinding and adjusting the valves because it had been grind and adjusted 6 months ago. I check the spark plugs but look all black. I pull the plug cable one by one during the running it sounds all ok. Now i wonder what is actually wrong with the engine? Do i need to adjust the valve clearance too? What is the valve clearance for both exhaust and inlet, hot and cold? If i do the valve adjustment and yet still the problem, what is next?
Jan 02, 2011 | Toyota Corolla Cars & Trucks
Have a GE GG40T6A gas hot water tank. Leaking really bad out of the pressure relief valve. It is a rental property, gas was off to the house (tenants moved out in the night). When the gas company turned...
12 year old water heater is getting near the end.
Some tanks last 20 years, but that's the exception.
To find exact age of your brand water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Leaking TP valve:
1) Lift TP lever and gently lower back into position to see if that stops leak.
Occasionally something gets stuck in the valve.
2) Sometimes water heater temperature gets turned up because heater is not producing as much hot water as before, and higher temps cause TP to release pressure because of overheating.
Dial temperature down to 120 degrees.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) If steps above don't fix problem, replace TP valve >> TP valves have 125 or 150 degrees rating >>> older tank shouldn't be running above 125 because higher temps cause more pressure on tank, so thermostat should be lower than 125 degrees TP rating.
Buy replacement TP at any hardware store + a roll of teflon tape to seal pipe threads.
Turn gas control to pilot ... this will keep pilot lit but burner will not fire.
Let water cool, and then drain some water out of tank.
If TP valve is on side of tank, then open drain on side of tank and drain water until it is lower than valve level. Open bathtub spigot to let air into line.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Be careful around water that is higher than 120 degrees F >> you can get burned quickly >> apply cold water to any burn.
Use pipe wrench and unscrew TP valve counterclock-wise.
Install new TP and put teflon tape on threads.
Re-fill tank completely and open tub valve on hot side until water is running >> then turn gas control back to original position.
Do not fire up any water heater before tank is completely full of water or this could damage tank.
To read more preventative information about water heater leaks and age problems:
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Nov 24, 2010 | General Electric GE SmartWater Household...
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have exactly the same problem
you need to change the cartridge, it is a temp control and is going bad so it keeps you from burning yourself it is like a mixing valve and is givng more cold water, that way you don;t get burned,,
Jun 18, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Kohler 30 year old single handle shower valve - cold water only
Is this a dual handle or single handle? if it is a single handle
turn the valve 180 degree. if not, then check the cold water supply line.
Jan 02, 2009 | Home
Cold water line
replace water valve and fill hoses
Mar 21, 2007 | Whirlpool LTE5243D Top Load Stacked...
Grohe rohe Grohmix Integrated Thermostat Valve And Trim 34436000-GH 9 1/2 Logo
428 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
