Question about Luceplan Solar Bud D29 Outdoor Light
The glass has a crack. can I repair? - Luceplan Solar Bud D29 Outdoor Light
Can i fix a nick in my large glass window from a small stone? no crack, just a nick
http://www.glasweld.com/glass-repair-protection/flat-glass-repair/
this website should help to find kits on repairing glass, from scratches to cracks
Jan 15, 2013 | Building Materials
How can I fix cracked screen
There is only one way to make your screen look better, but it will not "fix" the crack. I have done this and sometimes i cannot even tell my screen is still cracked and i didnt have to pay Apple $350 for a new piece of glass.
Here is what you can try:
1. Go to a auto parts store and buy a "Winshield repair kit" for small rock chips that look like a bullseye style chip.
2. CAREFULLY CLEAN THE GLASS WITH ALCOHOL and let dry for 10 minutes. Then heat up the glass of your phone with a hair drier for about 2 minutes so its hot, but not too hot to handle.
3. Then very, very slowly and cautiously, cut the tip of the nipple on the "epoxy/resin" bottle they have in the repair pack and while the phone glass is still hot (you may want to cut the tip of the bottle first, then heat up your phone), gentle squeeze the clear resin into and along the crack in your phones glass....Squeeze the resin directly along the entire length of the crack while attempting to squeeze it INTO THE CRACK...its diffucult, however, the heated glass will **** in the cool resin and actually fill in the crack.
Make sure not to get the resin on the phone or your skin!!!
AND BE PATIENT WHEN applying it.
ALSO, try to do this on a sunny day, because you have to place the glass in direct sunlight, or under a UV light to allow the epoxy/resin to cure. IT WILL NOT WORK UNDER A NORMAL LIGHT BULB. SUNLIGHT Actually works best.
Leave it in the sunlight for at least 1 hour or longer. Then wait another 24hrs before taking a razor blade to scrap off the excess resin that has built up on the glass.
FYI, it the crack to too deep the epoxy will seep thru the glass and this process wont work.
Jul 30, 2012 | LG Lucid 4g Lte Vs840 verizon Parts Or...
Vtech Mobigo screen cracked can it be repaired?
If this device is still working however the crack is small or not deep enough to affect the picture quality of the device, buy a cheap glass repair kit. This will not only fill the crack but ensure the glass stays protected and will look new. Also, after using the repair kit, be sure to use a anti-glare shied to further protect the screen.
If the screen is cracked to a point where the image is blurred, distorted or the colours are not accuratly displayed, unfortunately the glass will not be able to fix without speacialty parts specific to that device. If this is the case, I suggest you visit the site provided at the bottom and follow the steps indicated on the page.
Glass repair kit and demo:
http://www.youtube.com/watch?v=1FwIC7-bttk
http://www.amazon.com/Fix-Flat-Windshield-Do-Yourself/dp/B000EA5WLS
Replacement Parts:
http://www.vtechkids.com/support_replacement.cfm
Hope this helps. Good Luck!
Mar 13, 2011 | Vtech MobiGo Touch Learning System - Blue
Is a cracked windshield to dangerous to leave unrepaired ?
just leave it. A windshield is made of 2 pieces of glass with a plastic laminate layer in between the glass. The plastic laminate is what keeps you in the car in an accident. the crack is in the outside layer.
don't worry about it. It is not tempered glass and will not shatter like side and back glass.
Dec 21, 2009 | NRS Car Dash / Windshield Combo Mount...
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
Jul 31, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Skagen watch glasses keep cracking
Yes I would speak to Skagen in stron terms, this should not happen and wa probably aused by the glass being stressed when fitting it
Jun 18, 2009 | Skagen 170LTTM Wrist Watch
Cracked cook top glass
unfortunatley there is no way of repairing those. Even if you look at tops on the internet, they are usually about 1/3 of what the stove cost. Check your owners manual. Some of the tops are garunteed for 5 years from "accidental" cracks. That's about your best bet.
Feb 15, 2009 | GE Kitchen Ranges
Cracked glass (plastic) in SKAGEN 170LTTM
Found a skagen watch repairer in Melbourne , thank you
Dec 28, 2008 | Skagen 170LTTM Wrist Watch
Cracked glass on face plate
ebay, they are around $15, just be careful prying it off. You might have to take the top cover off to remove the glass. To put the new glass on close it all up first, then stick the new glass on. good luck
Nov 24, 2007 | Motorola Mobility RAZR V3
Luceplan Solar Bud D29 Outdoor Light Logo
506 people viewed this question
Top Luceplan Garden Experts
Dennis Key
Dennis Key
john h
Are you a Luceplan Garden Expert? Answer questions, earn points and help others
