Question about Panasonic Lumix DMC-TZ1 Digital Camera
Came with 2gb SD card wont accept 8gb SD HC 10 card what cards are compatible ?
    Top Expert:
  • Panasonic Master
  • 6,702 Answers
I know MMC, SD SDHC and SDXC all look the same, although the MMC has some more contacts on the back.
MMC is from about 8 Mega byte till 512 Mega byte.
The SD cards go up to and including 2 Giga byte.
The SCHC cards are more than 2 Giga Byte up to and 32 Giga byte
The SDXC cards are more than 32 Giga byte up to and including 2 Tera byte. Although now there are none available of the highest capacities.
The cards not only differ in capacity, but also differ in working signals.
You can find all specifications of SD cards on the internet, but some computer knowledge and a little knowledge of electronics would be nice to read these papers.
The development of these memory cards is going so fast, because there are also speed issues, when you use these for stills or for video and so on. Be aware most 1 GB SD cards already are SDHC
read this.
https://www.sdcard.org/downloads/pls/simplified_specs/part1_410.pdf
Posted on Apr 20, 2015
  • Panasonic Master
  • 5,631 Answers
It's a rather old camera
Read review here
http://www.imaging-resource.com/PRODS/TZ1/TZ1A.HTM
Get manual from here and check specifications; 2 Gb is the maximum it accepts.
http://www.manualslib.com/manual/360853/Panasonic-Lumix-Dmc-Tz1.html
    Top Expert:
  • Panasonic Master
  • 50,305 Answers
Read your manual it should tell you there
I got the e327 photosmart, and I jsut put in the 8gb sd card in the camera. Does not work. It wont even let me format the card at all. The screen turns on but I cant even take a picture. Can this camera...
The E327 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible and will not work in devices not designed to accept SDHC cards. You need to use SD cards, 2GB and smaller.
May 17, 2011 | HP Photosmart E327 Digital Camera
The only sd card i can find locally is an 8gb marked PNY SD HC it says on the packaging that this is new technology and only compatible with SD HC host devices. Is this card suitable for the Vivitar...
To be correct, the 8GB card is not an SD card but an SDHC card.
The 925DVR can use both SD and SDHC cards, up to 32GB in size. There should be no problems with the PNY card.
May 08, 2011 | Vivitar Cameras
SanDisk ULTRA II 8GB won't read when installed in a laptop. Works fine in the Digital camcorder. Trying to import the footage on to a Fujitsu tablet laptop (12 months old). Reads the standard 2Gb memory...
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
May 14, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
DVR 518 question regarding sd card compatibility;- will the product accept a SDHC card to 8gb I have difficulty in getting a standard SD card
The manual is not very precise but you cannot get normal SD cards that go to up 8gb, the highest is 2gb.
When they say 8gb they must mean SDHC.
Hope this helps.
Mar 19, 2010 | Vivitar DVR518 Camcorder
My Kodak P850 do not accept SD cards 4 or 8GB, error message state that memory must be replaced. No way to format the SD in camera. How can I do that camera accept the SD card
Technically speaking, SD cards only go up to 2GB. (Actually, some very rare 4GB SD cards exist, but I doubt you have one of those.) Cards 4GB and up are SDHC (Secure Digital High Capacity) cards. Your camera was designed before the SDHC specs, and thus is not compatible with SDHC cards. This is not something that can be changed in firmware, since there is a hardware compatibility issue.
SDHC devices will accept SD cards, but the opposite does not hold true. SD devices will not accept SDHC cards.
Jan 18, 2010 | Kodak EasyShare P850 Digital Camera
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
When i plug in my 8gb micro sd card my pc doesnt reconise it
is this a SDHC or some other type of high speed card ?
Does your SD reader accepts HC model ?
Have you tried a another SD Card ?
Regards
GeWiz.
Oct 17, 2009 | SanDisk 8GB microSDHC Memory Card with...
Access data on 8Gb SD card
Some older card readers will not read the newer HC-SD cards all memory cards larger that 4gb are HC-SD. You need to get a new card reader that states HC-SD compatible. Office Depot sells them as well as many online sites. Then just plug the new reader into a USB port and go.
I Hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 23, 2009 | Electronics - Others
My canon sd600 is not reading PNY sdhc memory card. msg says card is locked. it's clearly not locked
HC or High Capacity is not compatible with this camera. You have to buy a memory card which says only "SD" and NOT "SDHC". Cards of 2Gb and less are usually "SD". Cards of 8Gb and more are always "SDHC" for technical reasons. Cards of 4Gb can be either, but the SDHC kind are much more common, because they're cheaper and newer.
Jun 22, 2009 | Canon PowerShot SD600 Digital Camera
Wont read sd card 4 gb
You will have to upgrade your dash to windows 6 if you want it to read higher compacity micro sd cards. This method i free and is the only way their is no unlock code to make the the software compatible, you must upgrade it. once upgraded you can use up to a 8gb micro sd, i have not tried a higher card than that.
Jun 02, 2009 | T-Mobile Dash Smartphone
Panasonic Lumix DMC-TZ1 Digital Camera Logo
103 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
