Question about Konica Minolta bizhub C250 All-In-One Laser Printer
KONICA MINOLTA BIZHUB C250 Printed only magenta
Hello everyone, I did a Image adjustment process, and the A3 sheet color matching printed, put the sheet in the escanner and tighten Start, instead of printing the sheet with the reference colors, printed sheet with two squares magenta and now only the magenta print and photocopy of all images and textos.- what I can do? .- KONICA Minolta Bizhub c250 Thank you!
  • Konica Minolta Master
  • 6,161 Answers
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Posted on May 13, 2015
2 Suggested Answers
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Oct 28, 2015 | Konica Minolta BizHub C252
Malfunction C2553
Open close front door to reset. But your Magenta Image unit is having issues remove and shake the unit side ways to spread developer and toner whole length of the unit. Worse case get a new magenta image unit.. Also clean the sensor below the image unit when pulled out all the way near the front of the copier each color has one except black.
Mar 22, 2015 | Konica Minolta Konica Bizhub C250 Copier
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
Error code c-2833
CAUSE: LD Power becomes saturated when performing Auto Gamma adjustment in a low humidity condition.
SOLUTION: Perform the following adjustment:
1. [Utility].
2. [Machine Admin. Setting].
3. [System Setting].
4. [Expert Adjustment].
5. [Process Adjustment].
6. [Toner Quantity / Exposure].
7. Select the proper Exposure Adjustment [Yellow, Magenta, Cyan, or Black] by using the Next/Previous button.
8. Select Standard then select [-2] under Exposure.
9. Press OK.
Notes:
a. If the problem persists, replace the problem color drum since the cause of the SC is the combination of drum characteristic and humidity.
b. The following codes = colors: C-2831 = Yellow; C-2832 = Magenta; C-2833 = Cyan; C-2834 = Black.
Dec 03, 2009 | Konica Minolta bizhub C250 All-In-One...
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
I have a Konica Minolta Bizhub c351 and all of a sudden it started printing everything with a pink hue and the colors are very uneven.
There is a long process to solve the problem I might suggest that you have to call for service. It might be the magenta developer unit might be bad or rich the max life that need to be replace. Or just plain adjustment on colors setting. It might need to update the firmware to the newest level.
Mar 27, 2009 | Konica Minolta bizhub C351 All-In-One...
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Apr 17, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
164 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
