Question about Pool & Spa
Balboa filter circulation will not shut off. Temp OK. Not in continious mode.Contacts not stuck.
Open contacts manualy it shuts off. Timer? Please help?
  • 1,631 Answers
What model of balboa control do you have?
Will it come right back on after power down / power up?
Does it have a mechanical time clock?
Is temperature of water Hot?
when temp control is scaled down, will it turn off?
what do you mean - Temp ok?
If a mechanical time clock, pull the wires off of terminal 3 & 4,
isolate them! They will be HOT.
1 & 2 are for the timers internal 24 Hr. Motor.
but... First turn power off!
Turn power back on, if pump stays off, bad timer.
Posted on Apr 20, 2015
2 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: looking for manual tech info on balboa spa control
If you have a user manual check the filter duration isn't set to continuous.
Regards,
Ian
http://hottub.synthasite.com
Posted on Apr 17, 2010
Maytag washer repair
The washing machine timer can be considered the brain that controls the washing machine's systems. Although timers are ruggedly constructed, they contain a variety of tiny parts, like springs and movable contacts, that can develop problems that keep the machine from operating properly. The movable contacts can become burned and fuse together or they can become stuck in the open position, thus disrupting the wash cycles. The timer's motor can also become defective, thus preventing the timer from advancing through its cycles.
a defective timer motor, the motor's control contacts stuck in the open position or defective drive gears. Unplug the timer's wiring harness, then, with the timer set to any position other than off, check for continuity through the motor contacts. Continuity will be indicated by a "0.000" on the meter's display. A pictorial diagram on the back of the machine will tell you which numbers on the timer socket corresponds to which set of contacts in the timer. Likewise, a functional timer motor will display a resistance reading greater than 0.000, but less than 5 ohms. Open contacts or a defective motor winding will be indicated by an "O.L." on the meter's display.
IF A defective timer will only work in some cycles and not others. Then check for a broken wire in the wiring harness, check for continuity through those contacts using your meter. Wires in the wiring harness can break, but it's not a common occurrence unless they get pinched during the assembly of the machine.
If the same part of each cycle setting, such as the spin cycle does not operate properly, the problem probably is not the timer but some other component such as the transmission shifting mechanism. If the problem occurs when using only one cycle setting, the problem is a bad timer.
Jan 27, 2016 | Maytag Washing Machines
Coleman Evcon EB15B heat doesnt stop when it reaches the temp set on the themostat just gets hotter and hotter until I shut it of at the circuit breaker
Thermostat not doing it's job.
Probably the contacts on the thermostat are stuck together, Caused by arcing each time it opens.
If you are up to it.... clean the contacts or replace thermostat,
Cheers
Mar 03, 2015 | Heating & Cooling
Won't. Shut off
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Oct 02, 2014 | Dryers
Hand dryer won't shut off
will not shut off:
Aug 14, 2014 | Dryers
Changed timer/whirlpool model leq9508kq1/dryer runs in accudry mode, wont shut off,what is wrong?
if it wont shut off this is a timer problem contacts fused closed,are you sure this is a new timer?(some are remanufactured)
Feb 12, 2013 | Whirlpool GEW9250 Electric Dryer
Spa heateer run by Balboa 500Z control box. Standard mode will not shut off. Lowering temp to 88 still gets temp up to104.what is problem?
Sounds like the temp probe is not working or is disconnected. Temp going high, motor running means that it is calling for more heat which brings both the heater and the pump on until after set temp is reached. Once reached, heater will turn off and a few seconds later the pump will shut down.
Check connections for the temp probe. If connected make sure probe is where it should be. If it is, might try to replace it before considering the control board.
Aug 25, 2012 | Garden
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
The refrigerator on our Roper side by side refrigerator/freezer has frozen everything from veggies to milk. Any clue as to what the problem might be? Greg Russell
Your thermostat has probably got its contacts withing fried together and it is not shutting down.
Obviously the compressor and fans are working fine. It has to be in your control. Your ice box has a mercury based control. The temp is controled by it and nothing else. It can fail by burnt out contact. (open) OR Fried together contacts (stuck together won't shut down). OR Loss of mercury in the probe.OR kinked probe.
Aug 14, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
My balboa spa just keeps running constantly and never shuts off.
It may be in sleep mode or Eco mode. If you hit jets then lights it toggles through. You need to be on st mode. Which is standard
Feb 14, 2011 | Balboa Instruments BALBOA 30kW HEATER ASSY...
The compressor will not shut off when the temp reaches the set temp the fan stops but compressor does not then freezes up evap coils.the ac is a dometic 15,000 btu quick cool on a 1997 holiday rambler,it...
This is very much relay problem. The olden days relay get stuck due to residual magnetism. Or spring would have snapped. Or contacts would have bonded permanently. Check these or replace the relay totally.
May 24, 2010 | Dometic Rooftop RV Air Conditioner
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
