Question about Miele Refrigerators
Miele plate warmer esw5088-14 warming drawer will not close
The warming drawer will not close completly and stays open about 20 mm
  • catabej Jan 03, 2018
    i opened the drawer's back and the tamper ( shock absorber) is in a abnormal position, tryied to pull it back to the normal position - it worked for few days but it kiked back offsite and the drawer is not closing again. I noticed that the tamper is not moving smoothly as it should. I think the solution is to change the tamper. Any ideea of the part-number ??
  • 121 Answers
SOURCE: Samsung 1710 stops after warm up
Chances are, you're getting paper jams.  Try cleaning the rollers (as indicated below.)  If that seems to help the situation, then you'll need to get new feed rollers.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Posted on Oct 30, 2007
reg501
  • 413 Answers
SOURCE: The top drawer intermitantly makes the drawer opening noise
On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. Wipe these areas with a clean dry cloth.
Posted on Jun 01, 2008
jbjaxiis
  • 95 Answers
SOURCE: Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Posted on Jul 21, 2008
fieldy14
  • 456 Answers
SOURCE: LG DVD recorder/VCR Combo problems
you need to replace the dvd loader(the whole setup, the draw/tray,laser sled assy ,etc) statewide sell
parts for lg.unless you know an authorised lg repair agent.too bad you dont know me, lol.
(ps,its not in the manual,cuz there is nothing you can really do about it without serviceing the unit)
Posted on Oct 10, 2008
SOURCE: lg dvd drawer opens by itself and wont stay closed
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
Posted on Jan 28, 2009
I have a miele EGW2060 - Plate Warmer
you can download the manual from here
Jan 10, 2013 | Retail Supplies
How to replace a Miele W820 shock absorber
A couple of things: I was looking for a baby guide to shock absorber replacements.... everywhere it is said that it is "easy".. but none of the descriptions of the work that I read were complete. So, this is my attempt.
First, our W820 has no bottom plate, so access is possible through the base, contrary to what has been written: BUT, you might not need it.. read below.
The steps are as follows:
1) Open the washer door. Turn off and disconnect the power.
2) Remove the top: To do this, take out the two plastic screw covers on the left and right of the top and undo the screw. (Crosshead). The top can be hinged backwards and then lifted off.
3) Inspect the drum. Push it up and down; if it bounces more to one side then that is probably the location of the faulty shock absorber. It is good practice to replace both shocks at the same time. However in our case a repair man fixed just one ! a year ago and the bouncing showed that the shock on the right was faulty.
3) Remove the washer front panel. You do this as follows:
a) Remove the soap drawer and put it to one side, pulling it forwards and depressing the red plastic lever visible towards the rear of the drawer. This allows it to be slid out.
b) Remove the three star-headed screws holding the soap drawer surround in place (I used Allen screw drivers for this.. not good I know).
c) Open the panel used for draining the machine (front panel, bottom left) and unhook the plastic drain pipe which clips into the door.
d) Remove three 10 mm bolts from the front panel. These are around where the wash door would normally close (I hope you left it open from step 1)
e) The front panel can now be hinged open (hinges on the right) and you should be able to see inside. Take the opportunity to clean up any visible mess.
4) Inspect the shock absorbers. The right hand shock is visible through the bottom right of the front of the machine. It is a metal cylinder about 6" long fixed at an angle. The left shock is visible but hard to access from the front.
5) In our case we only need to replace the shock on the right. You need a 13 mm ring spanner and you can do the removal entirely from the front... without even moving the machine. Undo the bolts at the top and bottom of the shock and pull it out. Inspect it for confirmation of fault. In our case there was NO resistance to movement at all. If it looks to be in good condition then it is probably the other shock causing the problem. In any case replace both.
6) The left-hand shock needs the machine put on its side for access through the base. Put down some cushioning material, blankets, heavy cardboard, etc to protect the sides and gently tip the machine. Ideally this is a two-person activity. If not, be careful! Again, with a 13 mm ring spanner unbolt and replace the faulty shock.
7) How tight should you bolt the shocks.. as tight as you can with one hand. The machine is robust.. but breakages can occur if the ring spanner slips and hits wiring or connectors, so ensure that the spanner is always fully home on the bolt head and wiring pushed out of the way. I protected my hand from spanner slippage by wearing a gardening glove for this part of the operation.
7) Now all we need is to reassemble:
a) First close the front panel and bolt it shut with the three bolts around the door. These take the strain and should be bolted first.
b) Then we put back the three screws holding the surround for the detergent drawer. Don't over tighten.. it just needs to be firm, not rigid.
c) Reattach the drain plug to the door of the access panel (bottom left) and close it.
d) Lastly, replace the top of the machine, attaching the rear of the top first and hinging downwards, and then use the two screws and plastic screw head covers to complete the job.
You should now have a working Miele with several more years left to run.
When we bought our first Miele (in Holland) it had an expected lifetime of 20 years according to the store. It survived for 20 years, surviving moves across 3 countries. We then tried Hotpoint.. total rubbish and it died after 3 years. We are now on our second Miele and it is around 17 years old and, with this repair, working perfectly. Perhaps one more will see us into (and out of) retirement. In the meantime, it is worthwhile keeping these excellent machines in good condition. They are not throw-away!
Jul 14, 2012 | Cars & Trucks
How to change a miele W864 seal
First remove the dispenser drawer by pulling it out and pressing down on the red tab towards the rear and center. Next remove the 3 Torx 20 screws behind the dispenser drawer. Then you have 3 10 mm bolts to remove on the door panel where the door glass closes. After that you need to open the bottom left panel where the filter is and remove the plastic nozzle from the panel, then pull the door open. This gives you access to the door seal, it has a retainer ring with a 8mm bolt this will have to be loosened and pried open then the seal can be pulled off. There is a tab on the seal that has to be in the 12 0 clock position. Press the new seal on until you hear a pop and secure it with the band. Fit the lips of the new seal around the inner panel and close the door.
Jan 23, 2012 | Miele W864 Front Load Washer
Miele w1213 detergent drawer will not open - seems to be locked closed, child lock on/off has no impact
some machines have a drop down drawer lock on the front bottom edge of the drawer , it is usualy held up by a screw
Oct 31, 2008 | Miele 300 Front Load Washer
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Hello, Bosch Classixx fridge freezer warms up in fridge compartment, freezer seems OK. Is it just icing up, & I could switch it off for 48 hours? Or what to do? Thanks.
A defrost is more than likely necessary. Shut it off at the control and open the door. Also the little drawer or pan under the freezer compartment sometimes will have a baffle that can be raised or lowered to provide more or less air circulation. For a cooler refrigerator you would open the baffle, and for a warmer refrigerator temperature you would close the baffle for less air and warmer temperature.
May 05, 2008 | Refrigerators
Bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
Refrigerators Logo
97 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
