Question about Garden
It doesnt't want to go backward if on a hill or etc 250 hrs on mower
It goes forward ok no power backward
  • jerry czajkowski
    jerry czajkowski Apr 22, 2015
    i replace the belt , Idlers were ok also replace hyd. filter. thanks for the help it seem alot better.
  • 1,169 Answers
Most like it is the drive belt and idlers that are needing replacing especially if it is hydro unit. Many manufactures use a plastic composite idlers that wear out easily.
Posted on Apr 20, 2015
Cub cadet big country won't start in cold weather
The first cold startign in likely a choke problem.
The second all engines loose power under load.
Cub cadet are no usually high power machines.
Oct 12, 2014 | Garden
I got a troybilt rider mower. I dont know anything about mowers. I got this from a neglected owner and the final thing that got him to sell. Was the battery charger was wrong and it blew the acid all over ...
There should be a second belt that goes from the engine to the transmission. This could either be slipping due to a mis-adjusted pulley or another bad belt.
May 18, 2014 | Garden
Zero Turn mower no power in forward - power fine in reverse
yes check for play in linkage bushings the look for a adjustable rod
May 28, 2012 | Garden
Hi, I have a Kubota T1760 ride on mower that has a problem with the transmission. The mower goes fine backwards but struggles forward. Sometimes it goes forward but lacks power. Most of the time it...
my kaboto had the same problem ,kaboto dealer quoted me $2500 to fixand so i attempted to fix it myself and did so for $6.50 and its working like a new one
Mar 10, 2011 | Garden
I have a 1997 Polaris 250 trail blazer. It is an automatice and it will not go forward. It will go into reverse and drive backwards but when you try to put it into forward it doesnt really feel like it...
The problem is a worn shift fork in the transmission. Replace the forks and check forward gear pinions and forward shift dog pinions for wear and replace if they show any signs of wear.
Jan 01, 2010 | Polaris ATV
Moves a little after cleaning changing filter and oil. No torque, will not go up hill, no power will stop for a twig on the ground. Originally just stopped. I cleaned filter and changed and no broken were...
not a expert just trying to help,,i am asuuming the motor is running fine sitting still,,just will not move forward or backward to well,,, check your drive belt to see if there is any problems like pulleys springs or belt worn,,,,hope this help you
Sep 30, 2009 | Garden
I have a toro lawn mower it is a little hard to go forward but does go. It doesnt go backwards at all. Can you help me! Joanne
Check the drive belt for flat spots. If it is ok then it is probably an internal transmission problem
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
