Question about Apple Time Capsule 802.11 Wi-fi Hard Drive 3tb Factory Sealed A1409 3 Tb
Time capsule backup not working
Sparse bundle already in use. eject disk image?
Need a new hard drive but have no windows vista disk
You don't.
Do you have backup software? If so, do a "disk and partition" backup. This essentially creates an image of your system, even if you have multiple hard disks. Decent backup software (I won't mention any brands except the one I use: Acronis) will allow for a boot time recovery of your entire system, either by inserting a post-bios command -- which will appear on your screen before windows startup with a message like "Press F12 for system recovery", or you should press whatever key your system allows for boot order and boot from the recovery disk you can create from the software.
You can even now immediately create a Windows backup to an appropriately sized USB mounted disk (even the terabyte ones are relatively cheap) and a Windows Recovery Disk...the recovery disk should be inserted and use boot order F-key...good luck
Dec 28, 2013 | Gateway DX4200-09 PC Desktop
Maverick slows to crawl after time machine backup
Reboot and flash/reset PRAM hold down cmd+Alt+P+R keys when up and running repair Permissions (in DiskUtility).
OR restart hold down Alt key choose Recovery HD --use Disk Utility to check main hard drive for repairs etc
Nov 19, 2013 | Apple iMac Computers & Internet
OS Maverick very slow after time capsule backup
Use the App "Activity Monitor" to see what process is driving hard. if not already open: open the activity monitor window. Click the CPU% tab and show highest percentages at the top (should be an upside down triangle) may have to click the CPU% twice to do this. now the Activity monitor is showing you what processes are eating up your computers power. Google the process/es . It may be indexing the drive, which can take a long time. there are other processes too, that you should just let it do. once they are done, then things should be good. Such is the case for me when I upgraded to Mavericks.
Backup macbook pro harddrive
you can use the OSX built in "Time Machine" and connect an external HD or even better a Time Capsule WiFi station from Apple.
Can use Apple Time Machine to restore to new MacBook Ask Dave Taylor backup-macbook-pro-harddrive-abadwnk1mj4brvvpzp1wcyyy-4-0.jpg AirPort Time Capsule 2TB
Oct 17, 2013 | Apple MacBook Pro Notebook
How do i connect to apples time machine?
You can manually configure the time machine to accept wireless signal from the router or extender. If you setup WEP on the router or extender, make sure you setup WEP on the time machine as well.
For instructions in setting up wireless settings of Time Capsule click on this link -->>
http://www.apple.com/timecapsule/wireless.html
Hope this works for you.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
I used to have a linksys router but now have a Apple Time Machine. When I power up my WGA54G all i get is the power light. When I connect my WGA54G to the Time Machine, only the ethernet and power are lit....
Well, I'm not quite sure what your asking, exactly, but I'll try,
What are you wanting to connect the 'WGA to?
--"I used to have a linksys router but now have a Apple Time Machine."--
The Apple "Time Machine" is the backup "software" that controls the "Time CAPSULE'S" Hard Drive so I'll take it you mean the Time Capsule. The Time Capsule is already wireless.
The Time Capsule is just a wireless router with a Hard Drive in it. You should have set the Time Capsule up the same way you did the Linksys router. The Time Machine software on your computer can now access the Hard Drive for backup purposes.
"Time Capsule" connects to the '"WGA" wirelessly
'"WGA" is connected to a"Game system" (or network ready non-wireless product) via the Ethernet cable.
-"When I connect my WGA54G to the Time Machine,"-
OK,,,,,,, After looking at the manual on-line I think I know what happened, I believe the Manual is wrong! The "NOTE" mentioned to hook it to the Router first but how the heck are you suppose to access it from there? You CAN'T!
I think they had a "Brain Fade" and meant to hook it to the computer.
Hook the 'WGA to the Mac Book Pro and you should be able to access it now. You might want to make sure the MBP's Network connection LOCATION is set to AUTO to make sure it connects OK.
Make sure the switch on the side of the 'WGA is set to - infra- and not -ad-hoc-.
Hook an Ethernet cable to the computer then hook the other end to the 'WGA then plug the power cord into the WGA to turn it on and then try the Ip # it said to use in a web browser. If it then shows the log-in screen then enter them in like the manual said.
According to the manual if you can't access the 'WGA via the IP #192.168.1.250 then it some how got changed and you will have to reset it like the manual say's.
I hope I understood you OK, Good luck....
Jan 07, 2011 | Linksys Wireless-G Game Adapter [ WGA54G ]...
How do i make my computer just like it came out of the factory?
1. Recovery Disk - usually bundled CD with a new laptop or deskop PC 2. If the disk is not available, try checking on the manufacturers site if the recovery disk is available for download ( EMachine Homepage) 3. Some Desktop already have the recovery data saved on a slave drive. Try to verify the model of your Desktop and search it on their homepage
note: disk recovery will delete files, so be sure to backup important data before performing a recovery
Nov 09, 2010 | E-Machines eMachines Desktop PC
Cannot eject western digital passport
I've had similar problems with external drives. First of all if you have OS 10.4 it will recognize and format external drives that OS 10.5 will not. However the most recent update fixed some issues, so download the most current update by going to the apple and 'software update'. Next, if time machine has stamped the drive, then it will always 'see' the WD drive as the default backup and will write data to it periodically in automatic backup mode. If there is no data on the drive, or if you don't want to save the data then you could reformat the drive (first turn OFF time machine) by going to utilities and then 'disk utility'. If not, then try going to utilities and then use the 'air port' utility to work with the drive as it should be listed on the left as a time capsule.
Jul 07, 2009 | Computers & Internet
Apple Time Capsule 802.11 Wi-fi Hard Drive 3tb Factory Sealed A1409 3 Tb Logo
278 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
