Not linking to iMac
We changed low battery and haven't been able to connect since
  • 991 Answers
Press the button on the top right side of the key board, if the green light lights up you have power in the key board. Turn your mouse over and the green light should be on if the mouse has power.
Posted on Apr 20, 2015
I have iMac A1224 ecm 2266 and it wan't start up. i hear the chime, bu that's it. then black screen. i connected it to a tv and see picture, but no menu. keyboard working. i changed pram battery, but this...
Sounds like the monitor screen is shot! That's not good with that all in one computer! If it were a laptop changing the screen is easy! I hope you get it to work! I am searching for info for you! Hang tight!
Oct 05, 2014 | Apple iMac A1224 20" Core2Duo 2.66GHz 2GB...
My G3 1,5tb station does not show up on my iMac anymore. It used to work fine, without any problems and it has only been connected to my iMac. Now it does power up, but the station does not appear on my...
Check to make sure file sharing is still on at the G3. If it is running a Server app or OS X Server, make sure File Sharing Services is up and running.
Also, check the network connections on both computers. First, open the Network System Preferences pane on the G3 and write down its IP address (Note: you should have IP addresses showing on both computers, and if they use the same router subnet, the first three parts of the IP address should be identical and the last part should be different, but still between 0 and 255. If this is not so, you have a network problem between one computer and the router or other device that provides DHCP services.).
Next, on your iMac, open the Network Utility application (in Applications/Utilities). Click the Ping tab and type in the G3 IP address, then click the Ping button. If the network is good, you should get round-trip time statistics for each ping.
If the Ping test fails, then do the following steps to troubleshoot the network. Check to see if you have link lights on for both computers at the network switch, if not, check the network cable for the unlit port. If they are connected to different switches, also check the uplink port link lights on each switch. Testing a suspect connection is most simply done by trying a known good cable, a different switch port, or another computer with a known good network interface.
May 10, 2013 | Computers & Internet
Connect DWLG810 with Imac
Run an Ethernet cable from the iMac to the router.
Sep 22, 2012 | D-Link AirPlus Xtreme G DWL-G810...
Why can't I connect my iMac to my Dlink DIR-615 wireless router?
That is a older wifi access point and maybe the N is not compatible for your imac. I would get a dual band 2.4/5Mhz wifi Access Point.
Feb 02, 2012 | Apple iMac 17" MA199LLA Desktop
I'm trying to find a web cam w/mic that is compatible for an imac m5521
Hi Krystine. If your imac has firewire ports then look on ebay for an Apple iSight Camera.If you haven't got Firewire - and even if you have. it's wqorth looking here http://agent.liquiddigital.com.au/
This is a USB version of the Apple iSight in all but name.
I've seen it working and can vouch for its quality.
Sep 08, 2010 | Apple iMac G3 15" M5521 Desktop
Change battery in iMac
If u get this message it means ************ bord battey life is end and u should change it . it is 3v an remaining in mother bord. it mean your computer can not give actual date and time. contact to technican to change battery . it is not easy to change battery for us,
Oct 30, 2009 | Apple iMac G4 Desktop
Communication error between Epson Printer and iMac
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 27, 2009 | Epson Stylus Photo 1400 Printer
I currently use a cable modem to connect to the internet from my Imac. I have dlink wireless router that I used to have for my old pc so that my work laptop could connect. How do I install the dlink on the...
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Nov 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Cannot connect d link 1310 to imac
ignore the cd, temporarily,
try to connect to the router via its web interface at http://192.168.0.1
the wizards and helpscreens on the router if you can reach it are very good
the default admin name is admin password blank
which the wizards ask you to change once you get started.
For guest, check the settings on the macbook,
it may be configured to always ask for password,
a blank password may be valid
it may be configured to login to a domain, which it cannot find
Apr 17, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
