Question about Audiovox DT102A
Where can I get a replace 9V interface connector?
The current interface (plug) broke and you can not use the unit anymore, need to get a replacement one to resolder in place, this is where the external power source goes that charges and runs the system when plugged in, unless there is a better way to fix it.
I have a hunter 29185 remote control and the connector on the 9v battery broke off. Can it be repaired?
Yes... absolutely.
Your handy dandy electronics store... used to be Radio Shack..
That (real) old garage door opener in the bottom drawer...
any snap set that has the matching black/red connecter wires...
Red to red
black to black... a little heat shrink tube and some solder and you are back in business...
God luck.
Aug 19, 2016 | Hunter Fan Televison & Video
The battery on my EFX 546i Elliptical is only putting out 9 VDC. Too low?
If the battery is bad you will need to replace it. If its showing 9v you need to compare the reading to the rating of the battery. For example if the battery is rated at 12v then 9v is too low for the unit to function
877-805-1030
Book An appointment
Feb 25, 2016 | Exercise & Fitness
Turn power red light comes on temporarily then goes off and unit does not work just received unit via ups
- It's an issue with the DC 9V 0,4A jack (Power Supply).
There is not a right connection with the middle part of the connector.
The male connector of the record player is designed much too small
(or the female one of the adapter much too large).
I have used a crimped ferrule opened a little with a nail before.
- or check the adapter: Output DC 9V 0.4 A Direct(!) Current not AC
- plus in the middle of the Jack
Feb 28, 2014 | Crosley CR8005A-TU Cruiser 3 Speed...
Where can I find solutions for a power problem ? The unit will not turn on
- It is an issue with the DC 9V 0,4A jack (Power Supply).
How to i replace a 92 camry starter wire connector..i kind of broke the connector and it's just hanging
i dont understand what wire your talking about exactly however on the starter where it connects does it bolt on or push on if its a bolt on just go by at the local store a round eyelet crimp fitting with wire shrink it is like 6 bucks at the parts store
Apr 06, 2013 | 1989 Toyota Camry
I broke the heat synch fan connector when replacing the fan. My guess is that I probably will have to replace the motherboard as this connector is on the mb. My laptop is Gateway mx6448. Is there a...
if you only broke the connector for the cpu fan, why do you have to replace the motherboard? just cut the wires and solder them directly to the motherboard , if the pins have broke off, if the pins are still there then just bend them straight and put the fan plug on them
Apr 11, 2011 | Gateway Computers & Internet
The battery attachment for the 9V battery broke. One of the clips that attaches to the battery broke off when I was trying to take the battery out to replace it. Is there a way to add a new 9V battery...
if you are a bit handy, you can by replacement 9v packs/adapters that you can solder or wire nut on. Depending on what type of remote you have, it might be more economical to by a new one. the packs are ready available on eBay.
May 03, 2010 | Hunter 27185 Remote Control
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
Need to order a replacement part. Where can I do this? Made by Durabrand
Ebay has a gazillion 9V - 1.5A power supplys. Search first for ( "Durabrand" +power ) if you get no hits there then you can search under "laptop power supplies". Be sure to look closely that the connector that plugs into the unit matches, and that the power supply is rated at least 1.5 Amps or greater.
Mar 16, 2008 | Televison & Video
Spin brush not working anymore.
Is the shaft still on the brush block, if it broke off, then replace the block. if it is ok, then the turbine(#13) is most likely the problem. It is what drives the brushs. You may be able to take the turbine apart and clean it, if that doesn't work the replace it.
Mar 15, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Audiovox DT102A Logo
35 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
