How to repair second speaker on altec acs55. Primary speaker with output and sub works fine.
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
  • 77 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
Marinmeister
  • 11 Answers
SOURCE: ALTEC LANSING-VS-2521 SUB WOOFER AND LEFT SPEAKER
you probably messed something up in the subwofeer amplifier box, try taking them to a repair shop, or at the guarantee place.
another solution would be: you could try and fix them yourself but i don't recommend it.
Posted on Jan 15, 2010
pappapumpdaf
  • 635 Answers
SOURCE: only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Posted on Mar 09, 2010
joecoolvette
  • 5660 Answers
SOURCE: I was given an altec lansing acs55 pc gaming
TRS audio plugs.
2.5mm, 3.5mm, and 6.25mm pinout,
http://pinouts.ru/Home/Tele35s_pinout.shtml
Also look at the bottom at the color code chart.
More info,
http://en.wikipedia.org/wiki/TRS_connector
Posted on Nov 22, 2010
Altec lansing ada885
All of your speakers get power from your sub. The volume control may have failed or the connection to the sub may be loose or broken. The power light indicates only that primary power is getting to the sub; the amplifier ICs may have failed. It will be necessary to open up the sub (if possible) to find out what failed.
Nov 12, 2012 | Altec Lansing Audio Players & Recorders
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
I have a subwoofer can i hook up to computer speakers
Yes you can. cut the left speaker lead and splice a wire from it to your sub woofer. If its a powered woofer you may have too much gain going in, You don't say what kind of sub it is or weather or not its a "powered" unit. If its a powered woofer (built in amp) you should take the output directly from the computer output (buy a 1/8 in male to 2 1/8 in female connector, send one output to your original speakers and the left side of the second output to the sub woofer. you can usually adjust the level of the sub (if powered) with a control on the unit. if you need more help, contact me but please tell me more about what you have.
Mar 18, 2011 | Altec Lansing Multimedia Computer Speakers
I have an older altec multimedia 3 pc. computer speaker system my software has been damaged and I need drivers the subwoofer is a ACS160 and the speakers are ACS55
These speakers should work as long as your computer has the drivers for the sound card. I need to know what sound card you have, make and model of the computer, and the operating system; in order to direct you to the driver download. If you know of a computer with an operational sound card, test them on it. The speakers are passive devices - they don't need drivers to operate.
Feb 11, 2011 | Altec Lansing ® Multimedia 3pc...
Only one speaker works - altec lansing computer speakers ADA215
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
63 people viewed this question
 Grubhead
Grubhead
