Question about GE Refrigerators
Light going on and off on front panel and inside fridge
SOURCE: GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Posted on Oct 21, 2007
SOURCE: GE Profile Artica
The main PCB at the back of the appliance has failed
Posted on Aug 28, 2008
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A
service call is approx $80. The $80 will be deducted from the
part/labor if you choose to purchase/install parts from the service
technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
SOURCE: Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Posted on Mar 04, 2012
May 02, 2017 | GE Refrigerators
May 30, 2016 | Refrigerators
Jul 10, 2015 | GE Refrigerators
Jun 17, 2015 | GE Refrigerators
Oct 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 02, 2009 | GE Refrigerators
Jan 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Aug 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
May 14, 2008 | Refrigerators
98 people viewed this question
