X628-C BIOMETRIC TIME & ATTENDANCE READER wont allow me access with my finger
I tried setting it u as the admin, but it all of a sudden wont allow me access to set it up, i need to gain access to the menu area
xedcom
  • 127 Answers
SOURCE: time and date
While the unit is OFF, push down and hold the START button then turn ON the NDS. You can try the same with the SELECT or both buttons down.That must grant you access to the DS main menu.
By default the DS load the game cartridge when only one slot is used and let you choose when two slots are used. So if both slots are empty the menu must appear though your case would be very rare.
Good Luck...
Posted on Oct 17, 2007
  • 104 Answers
SOURCE: I can not access the set up page for WRT150N
Hi..if you haven't changed the defaults, try leaving username blank. The password is still admin.
Posted on Jan 04, 2009
  • 195 Answers
SOURCE: trying to gain access to system 32 files to change XP pro admin password
Once your in command mode, Your window starts like this. C:\> Your in C Drive. Type CD Windows, that puts you in C:\Windows, Type CD System 32, then you have C:\Windows\System 32. then type in your Make Directory. Good Luck.
Posted on Jan 07, 2009
SOURCE: Toshiba estudio 3511 will not allow me into the network config
First of all, the default password for Admin is '123456'. The network button is grayed out because network is initializing. Which means the network portion of you copier is trying to boot up. If it never finishes booting up, you will need an authrized technician to re-load system firmware on your machine.
Posted on Feb 04, 2009
Pristonero
  • 119 Answers
SOURCE: Can't access the config/admin page for my router (i have a Mac)
you can erset the router by press and hold for 15 sec the reset button at the back of router(using Ballpen or paper clip to reset it) but reseting it means configuring it again
Posted on Oct 22, 2009
Biometric fingerprint at start up wont read my finger
If you set up a password to start with, that is the way to go. If not, contact the programme provider for advice.
Feb 16, 2016 | Computers & Internet
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Bizhub C224 Color Copier /...
I forgot password of ls-838 lonestar biometric
The password is present to prevent the usage of it by a thief after it has been stolen.
May 25, 2014 | BestPriceCables Lonestar Biometric Time...
I dont know how intro the employes in my SL-836
Google your device with complete name/make/model etc. I would bet an operators manual can be downloaded. Or contact the manufacturer. Another thought is to check on eBay. I found a manual for a 1978 car.
Mar 19, 2014 | Biometric Time Attendance System, Model:...
Reset David-Link Model W-988PB timeclock
HI
RUN TIMECLOCK PROGRAM
GO TO TERMINAL CONFIGURATION
AND RESET ADMIN PREVELGE
Feb 17, 2012 | David -Link W-988 Biometric Time and...
Unable to obtain authentication input/output error has occurred. Error while loading applet Module is not registered.
Check to see if more than 1 biometric scanner is enabled @ device manager>Disabled all leaving only 1 supported finger print scanner enabled.
This error is most common if you have on-board or integrated biometric Reader...Try this 1st;still got answers if this doesn't work but it's been proved as remedy for this particular error :) Thanks
The Rule is:Help others without charge :)
Jan 10, 2011 | DigitalPersona UareU 4500 Fingerprint...
Finger print not reading
Hi, My Name is Henry. I am one of the technicians here.
The problem you are experiencing happens to a lot of people.
When you start your computer and waiting for the registry and everyother thing to load up, it takes time for the application that runs the Biometric to be loaded and that is why you have to wait.
As for 30 times of swiping, I think that is too long.
Try updating your Bios from the Dell Support. Go here http://support.euro.dell.com/support/index.aspx?c=uk&l=en&s=gen&~ck=pn
Choose drivers and download and follow the instructions. Be very careful because when updating the Bios it could actually mess you system if you do not follow the right instruction.
I believe if you do this, it may reduce your waiting time on the Biometric reader.
Regards
Henry
http://www.clickpcrepair.com
Mar 18, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Computers & Internet Logo
David Payne
David Payne
