Question about GPX Audio Players & Recorders
Model C253B I have figured out everything except how to turn the alarm off when not needed
I need help setting the alarm on my vintage Sanyo Model RM 5005 radio
I just brought the same one at a garage sale, after a bit of fiddling around, i figured it out
To set the time:
1. Hold down the 'real' button
2. While holding it down, push down hour until you have the desired hour (if you want pm, you need to go around until the 'pm light' is on
3. While still holding down the real button, push the minute button until desired number is reached
To set the alarm:
1. Hold down the alarm button
2. Follow steps 2 and 3 of setting the time, except with the alarm button held down instead of the real button
Jan 30, 2015 | Sanyo Audio Players & Recorders
Constant alarm but works fine otherwise
Jordan,
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
Car alarm tamarack
the alarm installed and everything worked except the center lock is locks but does not open through the alarm
Jan 06, 2012 | Radio Communications
What is the purpose of the body control unit?
Without having more specific information like year and model I can only give you a generic answer at this time, the body control unit is also known as the body ECU(electronic control unit) it controls just about everything in the car except for the engine, transmission and dynamic brake systems, examples: auto light turn on/off, daytime running lights, keyless entry, factory alarm, power windows, wiper /washers, auto A/C systems and more depending on the year and model.
Aug 17, 2011 | Toyota Previa Cars & Trucks
2006 New Beetle: Turn the key everything seems ok except the engine...
Try your other key. Sometimes after the alarm has been set off the computer no longer recognizes that key. Its part of the security system. It will crank buy not start. To use that key again it will have to be reset with something from the dealer or you can completely unhook your positive on your battery. Getting help from dealer is easier...believe me!
May 17, 2010 | 2006 Volkswagen New Beetle
Cant turn off alarm on RCA alarm clock model 3715A
Closest available RCA CD-CLOCK RADIO USER MANUAL online is for Model #RP5610 at this location: http://www.voxxsupport.com/images/manuals/RP5610/media/RP5610_DOC_OM.PDF
It is almost exactly the same model as the #3700 series.
If unable to link to that webpage, go to RCA Tech Support page at: http://support.rcaaudiovideo.com/manual.aspx?product=143 and click on download manual.
Nov 05, 2009 | RCA Radio Alarm Clock
2004 Ford Explorer not starting
Is the engine turning over? When you turn the key to the on position, does it behave normally? IE, do the battery and airbag and other lights come on when you turn the key to on position?
Dec 24, 2008 | 2004 Ford Explorer
Turn alarm off for weekends???
If its anything like the RCA model I have, you have to simultaneously hit the alarm button for the alarm you want to turn off AND the off button, so both at the same time.
Oct 26, 2008 | RCA RP5420 Clock Radio
Car alarm preventing car from starting
1999 CONCORDE: check the battery terminals probably they are not tight enough...something like that happened to me just the lights turned on and the car seemed to be dead, the battery is still ok since then. I just needed to buy new terminals.
Sep 20, 2008 | 1999 Chrysler Concorde
54 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
