Question about Air Hogs Toys
Why does my red light on my Air Hogs remote control helicopter only stay on for a couple of seconds and it won't charge my helicopter
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
  • 4 Answers
SOURCE: when i turn on the remote control, the red on/off
The batteries in the controller are nearly flat
Posted on Oct 02, 2010
micromatikal
  • 2777 Answers
SOURCE: Brookstone Silver Bullet Helicopter: When I
This is a battery fault, unfortunately pretty common. How old is this helicopter? It may still be under warranty.
Let me know, there is not really much of anything you can do on your end... you are doing everything correctly for sure.
Tim
Posted on Oct 09, 2010
  • 22 Answers
SOURCE: My air hogs sharpshooter is
mine started working!!! i just left the remote switch in the "charge" position overnight and then i put the switch all the way up the all the way down and it started charging.
Posted on Dec 14, 2010
SOURCE: my silverlit air hogs helicopter only goes out of control ON THE GROUND and it does not go up help!
Bad tail rotor, if you can't fix it rip it apart for parts and get a Syma S107
Posted on Dec 09, 2011
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
My sharpshooter and remote both turn on, but the helicopter does not react at all, what should i do?
I had this problem yesterday as well :)
My helicopter charged once worked and flew once for about 5 minutes. Then the helicopter stopped responding to the controller and it wouldn't take a charge. When I connected the remote to the helicopter the CHG light came on solid for about 30 seconds. This means that the controller is waiting to be plugged into the helicopter.
A couple of points to check before you go further:
1) make sure that the helicopter is turned OFF before charging!
2) When charging the red CHG light will blink.
3) When finished charging the red CHG light and the green Power light will blink at the same time.
4) After a certain amount of time both lights will stop blinking to save the batteries.
After taking the helicopter apart this is what I have found:
*The helicopter has a 140mA-H 3.7V Li-Po battery.
*The battery has a little board with 2 tiny computer chips. When the battery is empty these 2 chips will completely disconnect the battery. This prevents damaging the battery and this is why the helicopter stops responding when the battery is empty.
*There are two connections between the battery and the little board - a long connection which wraps one time around the battery and a short connection. My problem was with the short battery connection.
Solution --The little board has a short piece of foil which connects to another short piece of foil on the battery. These two pieces of foil are simply pressed together and then glued. In my case this connection broke. To fix the problem I removed the yellow tape and glue and used a soldering iron to solder the 2 foil pieces together. Make sure that you put tape (any household tape should be OK) back on the battery to prevent any shorts.
Dec 26, 2010 | Master Heaters Air Hogs Sharp Shooter...
We have two gyros S107G remote control helicopters. the instructions say to "set the band selector on the transmitter and helicopter to the same frequency." the switch on the transmitter is...
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
My son's air hogs hawk eye will not charge. What am i doing wrong?
Make sure that the switch on the helicopter is on charge (CHGE).
Dec 25, 2010 | Spinmaster Air Hogs Red Defender Remote...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Toys Logo
66 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
