Question about Sewing Machines
The wheel on the right no longer moves the needle, it spins freely. It will sewwhen using the footfeed but not by hand.
  • Sewing Machines Master
  • 627 Answers
The small handle attached to the hand wheel is the problem:
1. Loosen a small screw on the front or side of the small handle. Almost all the way.
2. Tighten the small handle as if you are tightening like you are going from loading a bobbin to sewing.
3. Tighten the small screw.
The wheel on the right no longer moves the needle, - 25655524-o3y3owyhie1i5efpkihkvrlo-5-0.jpg
Posted on Apr 20, 2015
My sewing machine shark euro-pro 361 is jammed. Needle will not move. What do I do
See if you can remove the bobbin from the machine. Most likely the bobbin and upper threads are entangled and have trapped the needle. You can remove the presser foot and loosen the needle from the needle bar (as though you are going to remove it). Then if you get a small pair of scissors in there and start nipping thread pieces and removing them with tweezers, you may be able to loosen it up.
Jan 16, 2017 | Euro-Pro Sewing Machines
How do I move the knife out of the way to thread needle?
The procedure on most machines is to flip the lever behind the needle carrier to raise the presser foot, then rotate the drive wheel on the right side of the machine by hand until the needle tip is completely clear of the presser plate over the bobbin. Make sure you turn the drive wheel in the same direction it spins when the machine is running - never turn it backwards.
Jul 15, 2015 | Sewing Machines
The needle acts like it is hitting something but there are no threads.
Test: Put needle on straight stitch. Put needle all the way to the left and turn the hand wheel forward.
Now move the needle to the right and do this again.
Did the hand wheel move all the way for one of the two sides the needle was placed?
If your answer is yes then you need to get the machine timed.
Also, make sure that your brake used for winding the bobbins is tight. If it is tight then loosen the small screw (usually on front of hand wheel). Move the brake forward a little more to tighten and then tighten the small screw again. Look at my picture.
Jun 26, 2015 | Sewing Machines
Hand wheel not moving
sounds as though the hand wheel at the right end of the machine needs tightening by hand to engage inner workings. Hold the larger wheel with one hand tighten the smaller wheel.
Dec 07, 2013 | Janome Memory Craft 3000
Singer 401a - hand wheel will not move needle except to hand crank
Make sure the lock is tight. If it is even slightly loose, the wheel will spin without moving the needle.
Jun 09, 2010 | Singer Sewing Machines
Needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Mar 14, 2009 | Janome Sewing Machines
Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Feb 13, 2009 | Sewing Machines
Hand wheel spins without moving the needle
I used to have an old Bernina that had an inner and outer hand wheel. Loosening the inner wheel disconnected the needle bar from the motor so you could wind the bobbin without running the needle up and down. It sounds to me like your machine has the same feature, but resistance on the needle makes the inner wheel loosen up. I don't know whether wrenching on it as tight as you can would be enough, or whether this is a symptom indicating that there is something loose internally in the connection between the inner and outer wheels. Good luck!
Jan 17, 2009 | White Sewing 1766 Mechanical Sewing...
Sewing Machines Logo
48 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
