Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
Machine wont accept cleaning tablet. Keeps beeping...
    New Friend:
  • 61 Answers
Either the funnel flap is damaged, or the microswitch that the funnel works with.
Posted on Apr 20, 2015
My asus tablet keeps beeping
Forgot password on a Coby Kyros 7012.How to reset it ?
Dec 01, 2013 | ASUS MeMO Pad HD 7
FQ-4 keeps beeping
it's possible that the motherboard that controls the embroidery
has a problem that needs servicing
Dec 22, 2012 | Sewing Machines
H owdo you clean the machine using the tablet ? Thanks
  1. Turn machine off.
  2. remove group head (portafilter)
  3. place single or dual cup filter in group head.
  4. place rubber bung in group head.
  5. place one tablet in space in bung.
  6. replace group head in machine.
  7. This is where the instructions lead you astray.
  8. DO NOT PRESS 1 & 2 CUP BUTTONS SIMULTANEOUSLY WITH POWER BUTTON.
  9. Press & hold 1 & 2 cup buttons simultaneously, on their own.
  10. Now press the power button while still holding the 1 & 2 cup buttons.
  11. Cleaning cycle will start, and will take around 5 mins to complete. Book says it will beep 3 times when finished haven't heard this yet. Just wait a couple of minutes extra and all should be well.
  12. Clean me light should be out and tablet disolved if not repeat steps again until tablet disolves.
Dec 08, 2010 | Breville Fresca BES860 2Cup Coffee Maker
Impressa S9 keeps beeping "clean now". Have run cycle several times. Tried cleaning out the tamping disk area. turned machine on and off. Still getting the "clean now" message and beeping.
There could be several reasons for this problem but I can only think of the following:
1.) The internal sensor may have gone "bad". The sensors are sensitive and prone to failure. But before you give up, see #2 & 3 below.
2.) A few things to check:
- Make sure you are using the recommended white cleaning tablets*. If the tablets aren't used then there may still be oil build-up in the brewing chamber.
- When indicated during the cleaning cycle, be sure to remove the tray and bean container for at least 20 seconds and then replace, even if they are already empty.
*Cleaning tablets can be ordered from www.capresso.com.
3.) If you don't have cleaning tablets on-hand then you can try running a regular brewing cycle using white vinegar** instead of water. Follow with at least 2 cycles of clear water (to rinse) before brewing your first cup of java.
***This method is probably not recommended by your manufacturer. I have used it on my machines without incurring any problems but I can't guarantee that it's safe for your machine.
Additional resources:
The entire pdf instruction manual for your machine can be downloaded from the following website: http://www.capresso.com/pdf/s9_instructions.pdf
Good Luck!
Jun 24, 2010 | Jura Capresso Impressa S9 Coffee...
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
AIR CONDITIONER MODEL #AF-S85FX--CODE E1 COMES ON-CLEANED FILTER, BUT UNIT WONT RESET AND KEEPS DEFAULTING BACK TO CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Jul 24, 2008 | Heating & Cooling
My cuisinart coffee maker DGB-900 series beeps and wont make coffee unless I turn it on and off a bunch of times. The filter basket just keeps turning and clicking. I have cleaned it and checked to make...
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
If it still not will operate, head it back to the store.
Hope this will help you
/Mirran
Jul 01, 2008 | Cuisinart DGB-600 Coffee Maker
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
119 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
