Question about Bosch Washing Machines
Wfmc3200 run diagnostic and see e20 c01 and d10 c01 codes. Bad motor or something in the drum support?
  • Jim valdes
    Jim valdes Apr 20, 2015
    Error codes from test P04 with an empty drum.
    Prodigy:
    An expert who has answered 500 questions.
  • Bosch Expert
  • 536 Answers
E20 error code: Short or break causing incorrect resistance in winding of the circulation pump or the motor.
D10 error code: Cause: Wiring/electrical fault related to motor triac.
Action: Check wiring on/to PCB and motor. Check the triac (on the PCB).
C01 error code: Cause: Motor tacho fault.
Action: Check motor and motor tacho wiring for problems.
Posted on Apr 20, 2015
Testimonial: "Thank you! I had interrupted the c01 as the wash cycle count? Jim"
In Xerox work center 7345 error coad 0004361 plz give me clearance of this
That error is a drum motor failure. It can be either a seized drum or a motor. Remove drums and enter diagnostics and test the motor first. If that passes put back in one drum at a time and then run the test after each one to identify bad drum.
Jan 12, 2016 | Xerox Office Equipment & Supplies
LG washer IF82 code. What does it mean? This is a washer not a dryer.
LE error is hall sensor is bad or bearing not letting motor turn
Aug 05, 2014 | LG WFT1071TP Top Load Washer
F11 code on whirlpool washer
Motor bearing has gone and heating up so that the position/speed sensor has moved/melted causing the machine to jump about. needs new motor bearings/ new motor.
Dec 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
I'm getting an error signal E20 when there is about 15 minutes left in the cycle. Ive tried clearing the hose, not sure what to do??
The most common cause of an E20 error code would be a clogged or damaged drain pump. Other possible issues would be a loose wire to you pressure switch, loose wire at your control board, loose wire at your drian pump, or failed control board. This is not a specific error but from my experience the most likely cause of this issue would be a bad drain pump. Something is clogging the pump or the motor is bad.
hope this helps _MJ_
Jan 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Bosch Washer WFMC3200.
Contact a Bosch technician. You may have to at least pay for a service call.
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
first of all, start with you close the door,you put the set on and continue please
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Maytag MAH21 - main motor won't run
Please check microswitch block door/ Best result change this microswitch on the new. If terminal is shot - longered on wire.
Rashid Moscow (arashid@yandex.ru)
Dec 19, 2007 | Maytag MAH21PDD Commercial Front-Load...
Kenmore elite 44832 front load washer troubleshooting F11 c01 c02
Was there ever a post back for this problem? I have the same issue, and I tried replacing the central control board, but it is still giving the F11 error. I follow the troubleshooting guidelines, but it never makes it past C01. I suppose the next logical step is to look at the motor control board and then the motor.
Sep 11, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
267 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
