Question about Lands Phones
How do I operate the answering machine? - Lands Phones
Switch problem
Hi Porl, my answer was assuming that your machine is the product in the picture, if your machine looks nothing like the picture then ignore my answer. It is not easy to answer questions when no specific model information is supplied.
Nov 30, 2013 | Krups Small Appliances Espresso Machine
Operating manual for att 1738 telephone answering machine
You can download a copy of the manual from
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=21714
Sep 23, 2010 | AT&T 1738 Digital Answering System with...
How to operate the answering machine
hi friend,
Step 1Call your telephone number and wait for the answering machine to answer. If you have left the answering machine in the off state then you should let it continue ringing until the machine finally answers, this may be as many as ten rings or more. When the machine finally answers, you may hear a series of beeping sounds.
  • Step 2Press "0" during the playback of the greeting message or during the series of beeps. Enter your PIN code within the next 2 seconds. You must know your PIN code to operate the answering machine remotely.
  • Step 3Wait for the prompt to enter a command code for remote operation. You will hear the machine report the current time and how many messages are in memory. The machine will then play a beep and wait for your command. To turn on the answering machine you must enter the corresponding code. You must enter the remote command within 15 seconds.
  • Step 4Hang up after the machine finishes the command and beeps. Call back to your number and make sure that the machine is now in the on state and will answer incoming calls.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Each brand and manufacturer of answering machines have different commands and PIN codes for the answering machines. Refer to your user manual for the exact codes and instructions on how to pick your PIN number for your phone.
    hope this helps u
    please rate me.......................
    thank u for using fixya
    regards
    sivaranjini
    Dec 01, 2009 | Panasonic KX-TG2343 Cordless Phone
    Lost my manual and cannot remember how to get messages remotely
    Since I have not idea what exact model you have this may or may not work... I hope it helps, as it is for a Uniden answering service phone.
    Remotely Operating Your Answering Machine
    Note: The answering machine will only playback messages for four minutes and then it returns to the command waiting mode.
    To continue playing your messages, press [#] then [2] again within 15 seconds.
    To operate from a remote location, use any touch-tone telephone and follow these steps:
    1.) Call your telephone number and wait for the answering machine to answer
    2.) During the greeting message, press [#] and enter your PIN code within 2 seconds;
    How to enter a PIN
    To play your messages from a remote location, you will need to enter a two-digit Personal Identification Number (PIN) or PIN Code.
    Press the MENU soft key. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
    Enter a two-digit security code (00-99) using the number keypad [0-9].
    Press the OK soft. You will hear a confirmation tone.
    The answering machine announces the current time and the number of messages stored in memory.
    You hear "To play incoming messages, press pound-two. For help, press pound-zero." You will hear a beep.
    Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following:
    # then 1 Repeat a Message
    # then 2 Playback Messages
    # then 3 Skipping a Message
    # then 4 Deleting a Message
    # then 5 Stop Operation
    * # then 6 Answering Machine On
    # then 7 Memo Record/Stop**
    # then 8 Greeting Record/Stop**
    # then 9 Answer Machine Off
    # then 0 Help Guidance
    Apr 27, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
    Help to record a message on my vtech answering machine.
    The VTech 2460 is pretty much the same telephone as the AT&T 2455. Here is a link to the AT&T 2455's User's Guide:
    http://telephones.att.com/docMgt/public/art/179/2455_manual.pdf
    Information about the answering machine operation begins on page 23/36.
    Dec 21, 2008 | Vtech 2460 Answering Machine
    How do you set the number of rings before the answering machine picks up?
    Here's a link to the manual on AT&T's site:
    http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=284
    Jun 08, 2008 | AT&T 1718 Digital Answering Machine
    Audiovox Digital Answering System Operating Steps
    i found this after searching the web for a long, long time.
    http://safemanuals.com/user-guide-instructions-owner-manual/AUDIOVOX/AXT847-_E
    Apr 01, 2008 | GE 29875GE Digital Answering Machine
    Swatch TDA03-1US Answering Machine
    try putting 01 into your analog phone after you have put in your 3 digit pin code
    how do you put in your pin code we have lost our operators manual
    Jan 16, 2008 | Swatch TDA03-1US Answering Machine
    Lands Phones Logo
    138 people viewed this question
    Top Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a Lands Phone Expert? Answer questions, earn points and help others
