Question about RCA DWA1015D - Digital Stream 10-Inch Droid Tablet
The power button on my tablet fell out while the tablet was off. How can I turn it back on?
    Sergeant:
  • 257 Answers
If still under warranty take back or contact maker .
Posted on Dec 28, 2015
2 Suggested Answers
  • 400 Answers
SOURCE: on button fell inside tablet.
I don't know what to do about Walmart, but perhaps you can fix, or work around the problem yourself. Tablets come apart easily, but you need to be careful. Take a very thin blade knife and gently pry around the edge of the screen. Work it up evenly, all the way around. With the screen off (it plugs into the main board), you should be able to locate the defective switch, in order to see if it is fixable. Perhaps it is broken, but you may be able to use a toothpick, or other object to activate the switch, after you take out the loose pieces, and reassemble the tablet. I doubt there is any way, short of a miracle, or someone very creative, to fix or find a replacement for the switch. Your next alternative is a new tablet. I hope this is helpful. Let me know if it is... or ask more questions. Thanks.
Posted on Mar 30, 2014
Is there anyway to turn on tablet if the power button fell off??
there is a tiny detent button right behind the plastic that fell off
it will take a toothpick or pen to press it
May 09, 2015 | Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
Why want my tablet come on?
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on. Support Troubleshooting Guide
Aug 07, 2014 | Kocaso M1060W Tablet
Won't turn on
Mar 27, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Android tablet won't turn on
Feb 20, 2014 | Kocaso M1060W Tablet
Can not unlock my coby tablet
it seems like that your tablet's touchscreen panel has a defect, to get the full functionality of the touchscreen panel it should be replaced...
Sep 03, 2012 | Coby Tablets & eReaders
RCA DWA1015D - Digital Stream 10-Inch Droid Tablet Logo
49 people viewed this question
Top RCA Tablets & eReaders Experts
Christoverre Kohler
Christoverre Kohler
Lawrence Thornton
Level 1 Expert
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
