Question about Dehumidifiers
I don't see a place to hook up a hose for continuous run into the sub-pump pit. I removed the drip pan and still don't see a place to hook up a hose.
    New Friend:
  • 26 Answers
On some models a separate extension tube gets installed through a knockout on the back panel. The extension tube fits into the part where the condensate drips into the pan; the opposite end has threads for a hose. This tube (if applicable to your model) should have been in the box with the unit. There isn't any information on the brand or model you have. Looking at the instructions for your model should also provide an answer. If you no longer have the instructions, turn the unit on and try to locate where the condensate drips into the pan. The hose would have to connect from there.
Posted on May 06, 2015
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
WHEN HOOKING HOSE TO DEHUMIDIFIER, DISCHARGE STILL GOES TO PAN AND NOT THROUGHT HOSE?
have you removed the knock out plug out of the pan where the hose connects
Sep 13, 2010 | Maytag M7DH65B2A Dehumidifier
Trying to use the hose rather than emptying the bucket but water continues to drip onto bucket even tho connection to hose appears snug
This may not help because I'm not sure of what you have, but most dehumids when using a hose hook to a fitting on the tank. If that's what you have, before you hook the hose you have to either punch a knockout in the center of the hookup on the tank or cut it out. Hope this helps.
Aug 30, 2010 | LG LHD65EBL Dehumidifier
My dehimidifier is not draining thrrough the hose
Run a straightened coat hanger through hose or try to blow through. Or connect to faucet to clean out clog.
Make sure drip pan is clean & level. Basically vacuum any dust from inside drain area.
Apr 14, 2010 | DeLonghi DE500 Dehumidifier
I have a dehumidifier in my basement and attached a garden hose to the outlet and have it draining into the sump pump drain--however it's draining into the bucket and not through the hose. And I cannot...
WHEN I BROUGHT MINE I HAVE A HOSE RUNNING TO A FLOOR DRAIN BUT REMOVE THE HOSE SEE IF THERE IS A PLASTIC COVER INSIDE WHERE THE HOSE HOOKS ON FROM THE FACTORY THE CONDENSATE PAN IS MENT TO HOLD WATER AND THIS PLASTIC PIECE HAS TO BE REMOVED FOR HOSE USE
Aug 23, 2009 | Amana Dehumidifiers
How do i hook up plastic attachment so i am able to run a hose to a drain for continual usuage DH404E
Most brands have a fitting molded into the drain pan that will let you attach a garden hose to the tank. You may have to drill a hole in the fitting to allow the water to drain through.
Aug 18, 2009 | Goldstar DH304 Dehumidifier
Continuous drainage
Take out the drain pan and look in left hand top of the compartment and you will see a drain hole for the pan.Plug the drain hole with a small rubber plug, I used an electrical wire nut wrapped with tape and it worked fine.replace the pan and the water will run out the back. A 3/4" garden hose should work for the drain hole.
Jul 27, 2009 | Haier HDN655E Dehumidifier
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Apr 25, 2009 | Danby DDR601 Dehumidifier
Dehumidifier collecting water in container
If you have the hose drain tube connected, drainage will defer to it first. If you remove the hose drain tube, the place where it connects to the drain pan drips into the container instead.
Sep 17, 2008 | Maytag M7DH65B2A Dehumidifier
Dehumidifiers Logo
243 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
