Question about Onkyo TX-NR636 Receiver 7.2 Channels, 95 W/Channel, 0.08% THD, Supports 6 Devices
How do I correct a "check SP Wire" error
What parts needs to be changed?
  • Official Brand Answer
  • 333 Answers
Hi Carl, typically this would be an indicator that one of the bare wires from your speaker connections is coming in contact with the back panel of the unit. Please disconnect all of your speakers and power on the unit to see if you get the same message. If you do not then you know the problem is with the speaker connections. Now if the unit shows check speaker wire with no speakers connected it would mean that the unit will require servicing, Thanks, JT
Posted on Jul 31, 2015
How to fix error code 6 on a roger black treadmill?
1)E00 Safety Key not in the position Re-locate the safety key in the correct position.
2)E01 No signal to Controller from the console
A: Check the Main Controller Wire
B: Replace the PCB Board
3)E02 Motor communication error
A: Check the wire from motor to controller
B: IGBT breakdown, Replace the controller
C: Check the power voltage if 50% lower than rated voltage
D: replace the motor wire or change motor
4)E04 Incline Motor communication error
A: Check the wire from incline motor to controller
B: Replace the incline motor
C: Replace the controller
5)E05 Over current protector
A: Overloading or over resistance,
restart the treadmill
B: Transmission parts seized up, check the parts
C: Replace controller
D: Motor breakdown, change the motor
6)E06 Motor Open Circuit.Connect the Motor link
7)E08 IC Driver Error. Replace the IC driver or change the
IC driver
8)E09 Folding up protect.
A: Do not fold up the running deck when treadmill in is running
B: If the running deck in laying position and show E09, you need to change the controller
9)E10 Motor instantaneous current abnormal
A: Adjust the torsion potentiometer of the Controller to lower
B: Motor Breakdown, change the motor
10)E11 Overvoltage protector Voltage over 270v (for 220v) or 150v (for110v) -- turn off the treadmill and check the power source
11)E13 No signal to console from the controller
B: Change the controller
12)E14 Lower voltage protector Voltage lower than 160v (220v) or 70v (110v) -- turn off the treadmill and check the power source
Oct 26, 2017 | Exercise & Fitness
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
How do I remedy error SC 552?
change the main motor or clear the eroor
Sep 10, 2015 | Ricoh Aficio SP C811DN Laser Printer
Receiver shuts off says check sp cable
The reciever is telling you that their is a problem with the speaker cable. I sugges pinpointing which speaker cable it is by turning the system off then unplug all the speaker cables and then plug one in at a time, waiting inbetween allowing enough time for the system to pick up the bad sp cable. Then once you find the correct cable check it from the reciever to the speaker for any signs of breakage, shorts, or damage. Check the speaker connections from wire to speaker and from the wire to the reciever. If all that fails then check the speaker itself, try swaping another one in the position to see if the problem is solved. Hope this works.
Mar 06, 2011 | Yamaha RX-V2700 Receiver
Getting error: set fusing unit correctly on Ricoh Aficio SP C410DN. Have just changed thermister in fusing unit.
Take the unit out and install it again, making sure it is in all the way and sitting correctly. Then reset the machine and see if the error goes away.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
Unit turns itself off after diplaying code "check SP wire"
My guess, guess, check CLOSELY the SPeaker wires - "Check SP wire" make sure all of the bare portion of the wire is into the terminal. No bare wire touching another bare wire both at the receiver and at the speakers. Also, if the wiring is not continuous, check all connections of speaker wire. Disconnect all but one, play it like that. If no problem, label that as good, disconnect another for several days, when one shuts Rec. off, check wires closely for that speaker.
Jan 23, 2009 | Yamaha HTR-5650 Receiver
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Zoom Error
Have you tried changing the batteries to new/charged ones?
Jul 21, 2008 | Olympus SP-310 Digital Camera
Epson dfx-9000
the SP motor brake signal didn't switch on within 3 seconds after turning printer on.
check for disconnected SP motor-related connectors. the printer needs servicing.
Jan 15, 2008 | Epson DFX-9000 Matrix Printer
Onkyo TX-NR636 Receiver 7.2 Channels, 95 W/Channel, 0.08% THD, Supports 6 Devices Logo
280 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
