Question about Mygica LDA-9000 HDTV Box 1080P With Hybrid ATSC/Clear QAM/NTSC TV Tun
Watching pc output on TV
I want to connect my PC VGA output on my TV that has S-video but no HDMI using Mygica LDA-9000 HDTV Box 1080P With Hybrid ATSC/Clear QAM/NTSC TV. What are the steps?
My laptop doesn't have a HDMI port so I have to connect with two cables...I think ones VGA and the other is audio. This goes into the back of my old smaller tv...which is ok but I'd like to route the
Your TV doesn't have video output on either HDMI or Composite video. (There are a few TVs that do have a video out but often that is only available for some input/output combinations. You would need to check the manual but the PC input is usually not available for the video output.)
You could get a VGA to composite or component video converter and direct the signal to your new TV from your PC. One example of the first converter is here: http://www.cablestogo.com/product/29548 . An example of the VGA to component video is here: https://sewelldirect.com/audio-authority-vga-to-component-pc-to-hdtv-converter.asp . There are other models available. A few VGA to HDMI converters also exist. However, since those need to convert an analog output to digital, they are more expensive.
I hope this helps.
(A few VGA to composite cables exist. They will not work for your purpose. They are designed to connect projectors with RCA ports and understand the VGA RGB signal to a computer.)
Jan 15, 2015 | Computers & Internet
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Will my video card support connection to my hdtv
It is unlikely to work. VGA is an anlog signal while HDMI is a.digital signal. Hope this helps.
Apr 01, 2012 | HP Pavilion Computers & Internet
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
Is it possible to connect my computer with a VGA output to my HDTV with HDMI inputs?
hi there, sure it is.
either check if the video card has two output interfaces(VGA and HDMI) so use the white HDMI-otlet with a cable and your TV, else do get an VGA-to- HDMI adaptor and try connecting the VGA outlet and your TV-set.
Good luck
Sep 13, 2009 | HP COMPAQ Presario SR5410F Pentium...
How to use my HDTV for a monitor for my computer
What video output connection type do you have on your PC.....DVI, VGA, S-VIDEO, HDMI?
What video inputs connection types do you have on your HDTV.....DVI, VGA, S-VIDEO, HDMI?
The cable you need will be whatever connection you have....ie: DVI----->HDMI or VGA----->VGA or DVI to DVI.
You will also need an audio cable, 2 Phono RCA Red/White (Left and right) -------------> audio output jack plug or Optical in------->Optical out
Thanks
Sep 05, 2009 | E-Machines eMachines Desktop PC
No signal on HDTV
Your graphics card is probably too old to support HDTV signal (720p, 1080p)
Dec 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
I am trying to connect my PC to my TV. I have a Sharp HDTV and my PC is a Toshiba with windows XP. I have a componert video cable which is connected to the TV and PC. I have used Fn and F5 didn't work....
what model of TV was it please,
Does your computer have tv out video card installed?
For video to tv you will need a vga to tv converter,this is an external device and will work on the computers vga output straight into a vga input and give you 1 x vga out,1 x rca out, 1 x s/video out,comes supplied all prebuilt with onboard graphics solution. no extra power required runs straight of vga output.
Once the computers video output is established then set the TV up to tune into the converters output signal.
HD TV can be set up to run thru rca and components and if model is late enough shuld come equip with serial vga input for computers.Other than that HDMI seems to be the better quality of picture over rca component.Cost verses dollar really and function.
Cheap fix VGA to TV CONVERTER
Expensive Fix HDMI to HDMI
(it is posible to hdmi over cat5e)
NO COMPARISON FOR QUALITY.
Jul 10, 2008 | Acer Aspire 3680 Laptop
Mygica LDA-9000 HDTV Box 1080P With Hybrid ATSC/Clear QAM/NTSC TV Tun Logo
296 people viewed this question
Top Mygica Computers & Internet Experts
David Payne
David Payne
Are you a Mygica Computer and Internet Expert? Answer questions, earn points and help others
