Question about Garden
What is the cause of gas leaking behind the air filter
    Top Expert:
  • Garden Master
  • 44,393 Answers
The float is not closing of the needle on it's seat
probably a bit of dirt /hair in the line
remove the carby and clean it out
Posted on Apr 20, 2015
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: cannot get mower to start.
Hi mikpanos...
Here is some help for your problem...
Check to make sure you are getting fire/spark at the plug, if so then do the following:
Check/Clean/Replace your fuel filter if you have one.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 18, 2011
al_kupchella
  • 843 Answers
SOURCE: I changed the air filter, pre-filter, fuel filter,
Sounds like the float valve is sticking open. You will have to drain the gas (or at least turn off the valve where the gas leaves the tank if so equipped.) Then remove the bowl to clean the float valve. (There is usually a nut in middle of the bowl.) The bowl looks like a bowl, and is about 2 inches in diameter. When you remove it you will see the float, which probably looks like a little brass donut. If you remove the hinge pin that allows the float to move up and down (it only moves about 1/2 inch) you will then allow the valve pin to fall out. The valve pin is about 3/4 inches long and maybe 3/16 diameter. (I am not measuring these things, just giving approximate dimensions so you will recognize them when you see them.) Good luck, Al K
Posted on May 19, 2011
Gas is leaking after I put gas in. It looks like the fuels lines are in. Does the filter attach to the gas lines? I don't see an air filter on my 536-77240000 craftman edger.
If you just replaced the lines, alot of times the lines outerm diameter is not correct, causing leaks...other times its the gas cap itself, However, there shouldn't be any hole under a gas tank... at least not where any air filter would be close by..
Sep 26, 2015 | Garden
How do you solve the problem of fixing .The code P0170 in a Suziki verona 2004
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
NOTE: Dirty air filter, air filter housing or Mass Air Flow (MAF) sensor, or faulty MAF sensor are common causes for the P0170 code
Apr 06, 2015 | Cars & Trucks
How do you fix code P0170 in volvo s60 2.5t
P0170 - Fuel Trim Malfunction Bank 1
Possible causes
- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
Tech notes
Dirty air filter, air filter housing or Mass Air Flow (MAF) sensor, or faulty MAF sensor are common causes for the P0170 code.
May 10, 2013 | Cars & Trucks
Car quits when i push on the gas
car quit when you accelerate,could have stopped up fuel filter or weak fuel pump, check fuel pressure with new fuel filter should be 40 - 47 psi.if fuel okay could have massive intake leak,check for air leak at the air intake duct if air intact duct goes to air filter is open that will cause intake leak or intake manifold gasket leaking or ignition timing off timing chain could jump time for high mileage engine.
Sep 08, 2012 | 1995 Buick LeSabre
Scanned my computer , came up with a PO 171 and 174 what does this mean?
P0171 AND P0174
P0171 - System Too Engine Cylinder Lean Bank 1xicon.jpghttp://engine-codes.com/p0171.htmlForum CodePossible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes Dirty air filter of faulty air flow sensor are common causes for the P0171 code of the problem.
P0174 FORD - Fuel Injection System Too Lean Bank 2xicon.jpghttp://engine-codes.com/p0174_ford.htmlForum CodePossible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
Jul 27, 2012 | Cars & Trucks
What does error code p0172 and p0174?
P0172 - Fuel Injection System Too Rich Bank 1 Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
Possible causes - Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connec
Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem.
P0174 - Fuel Injection System Too Lean Bank 2 Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Exhaust gas leaks
- Lack of fuel
- Incorrect PCV hose connection
Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem. Bottom line possible defective Mass airflow sensor and or O2 sensor in cylinder bank number two.
Feb 21, 2011 | 1998 Ford Expedition
What cause the bank1 and 2 too lean
P0174 - Fuel Injection System Too Lean Bank 2 Possible causes - Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem. P0171 - Fuel Injection System Too Lean Bank 1 Possible causes - Intake air leaks
- Exhaust gas leaks
- Lack of fuel
Jan 11, 2011 | 1998 Chevrolet S-10 Pickup
OBDII SETS CODES P0401, P0171 & P0174 . 1998 Mercury Sable
P0401- Exhaust Gas Recirculation Flow Insufficient Dectected
Possible causes - Harness or connectors (EGR volume control valve circuit is open or shorted.)
- EGR volume control valve stuck closed
- EGR volume control solenoid valve
- Dead (Weak) battery
- EGR passage clogged
- Exhaust gas leaks Possible solution - Clean EGR Valve
- Repair EGR harness or connector
- Replaced EGR volume control solenoid valve
- Replaced EGR volume control valve
Code P0171- Fuel Injection System Too Lean Bank 1 Possible causes - Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect PCV hose connection Possible solution Dirty air filter of faulty air flow sensor are common causes of the problem P0174- Fuel Injection System Too Lean Bank 2 Possible causes - Intake air leaks
- Exhaust gas leaks
- Lack of fuel
Jun 28, 2010 | 1998 Mercury Sable
I have a troy built pressure washer leaking gas from the air filter i looked around for advice and hurd bang against the carb and it will realease the float valve i did it and it worked but should i clean...
definetly replace the paper filter and yes Lowes will carry them.if it does not leak now, I would leave it alone or you will be installing a nine dollar kit.The briggs kit # is 294260 is you choose to do it anyway
Nov 15, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
My 2003 subaru forester idle very rough. if you open the hood and look at the engine it is shaking like its firing on only three cylinders. I need some help.I changed the spark plugs, gas filter, air...
1) Check all the vacuum hoses for a leak in the rubber hose or a hose that isn't connected. Vacuum leaks cause motors to shake and stumble on acceleration.
2) There's a plastic T connection on the back side of the engine behind and under the air cleaner box. That T connector joins together three air hoses of different sizes and is prone to breaking from heat stress. Only a Subaru dealer will have this part.
3) Even though the spark plug wires are new, you may have a bad one. Don't waste your money on cheap parts; they cost more in the long run.
Apr 23, 2009 | 2003 Subaru Forester
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
