Question about Frigidaire Washing Machines
Replaced water inlet valve on washer but now it fills a little stops for a few minutes fills a little stops for a few minutes then keeps repeating
GLTF2940FS1
    Genius:
  • Frigidaire Master
  • 1,585 Answers
Check pressour switch
Posted on Apr 21, 2015
Why is my washer saying low water pressure. How can I fix that without have someone come out to repair it
It depends on the cause of the water pressure issue. I'd first check your incoming water to the washer. Turn off the inlet shut-off valves and disconnect the hoses. Check the hose filters and the inlet valve filters. Remove any debris. Next put a large bucket under the shut-off valves and open them fully for a minute. Check how much water flows into the bucket. If very little water was in your bucket, you'll need to check where the restriction is in your water lines. (The water pressure needs to be sufficient to fill the washer in about 8 minutes. Depending on your home, you may need a professional to check the water at your water connection to the city or at your well pump.) Empty the bucket. Replace your inlet hoses at the valve side and repeat the test. If you are getting low water flow with the hoses in place, replace the hoses. Some hoses have a "anti-flood" feature which restricts the hose if there is a problem. (I've seen the hot water flow rate to the washer significantly decrease due to the hose blocking the flow. The cold water hose was replaced at the same time to avoid it failing in a short time.)
Next check that the drain hose isn't below the level of the water in the washer. This can cause siphoning and empties the washer as fast as it fills.
If the water pressure is still low after testing these items, the problem could be the inlet valves on the washer or the air pressure at sensor that detects the water flow. On some washers, you may be able to remove the debris in the air tube. However, if there is a pinhole, that part will need to be replaced.
I hope this helps.
Oct 05, 2014 | Samsung WF328AA Front Load Washer
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Water keep filling til machine overflow and need to turn of water inlet valve
if you have to shut off the water supply valve of the residence (water keeps flowing after turning off the washing machine or unplugging the washer), the failed component is definitely a stuck open water inlet valve (fill valve) of the appliance. If the water stopped by pushing the timer or unplugging the machine, another internal electrical control related problem exists, such as a faulty timer assembly or controller board, or a pressure system failure (water level detection/monitoring system) - failed pressure switch (rare), clogged air hose or tub air dome (common in GE top-load washers), disconnected air hose (common in frigidaire top load washers & GE/Frigidaire/Kenmore stacked washer/dryer combo units).
While a simple repair can be done by yourself for a failed inlet valve, usually for $25-$50 in parts/shipping (go to searspartsdirect.com or appliancepartspros.com to look up a replacement fill-valve using your washing machine model number), the water damage potentially caused by the flooding is more important to address.
I recommend contacting your insurance company if there's a bunch of water that flooded your home - the water can cause delayed warping of flooring or cause mold to grow in/beneath your carpets and walls if the water was not immediately noticed and cleaned up (within first few minutes of flooding) - they send out water remediation specialists to dry (if possible), or to repair the damage to your home.
Dec 26, 2011 | Whirlpool LSQ8243H
No fault code washer will not fill
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool WTW6400SW Cabrio Washer
My washer wont fill with water what seems to be the problem
Hi
Daniel
Aug 10, 2011 | Samsung WF210AN Washer
Water not entering washer
Hi
Daniel
Aug 03, 2011 | Maytag Bravos MTW6600T Top Load Washer
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
My washer will not stop filling with water and overflows
Turn the washer on and let the water run, while the water is running unplug the power cord if the water stops the inlet valve is ok but if still running the valve is bad and need to be replace if the pump is good you need to test the water level switch, if faulty need to replace.
good luck
Mar 17, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
