Question about Brother Sewing Machines
Model CS8150 bobbin winder doesn't want to wind
  • 948 Answers
Hi. I found some instructions for you. I hope this helps! :)
http://www.manualslib.com/manual/355759/Brother-Cs-8150.html?page=24
Posted on May 03, 2015
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: Janome sewing machine bobbin winder
I had that problem the first time I tried to wind a bobbin. What a mess. The next time I let the thread run through my finger and thumb before reaching the bobbin. I had to do the same on a previous Kenmore.
I've also found that the heavier Bernina bobbins don't 'jump' around.
Posted on Mar 25, 2008
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
  • 980 Answers
SOURCE: I have a singer 503A. The bobbin winder will not
When you have the winder rubber on try and turn the winder by hand, if it does not move the chances are the winder has seized, if the winder wheel is moving but not the spindle then the grip (thread) has worn, if you cannot move the whole winder by hand and it has seized you need to get some WD40 and spray a few drops down the spindle, take an electric drill and put it over the top of the spindle and switch it on slowly and it will probably free it off, be aware of oil splashing out.
you mighjt get a digram from www.tandtrepair.com
Posted on Feb 24, 2010
  • 1116 Answers
SOURCE: bobbin winder will not wind
The bobbin winder will not activate to turn the bobbin or the thread will not wind onto the bobbin spool?
Sewing machines vary in the method used for bobbin winding.
You can find threading and bobbin winding guides at sewusa.com.
If the winder is broken, you can get it repaired or check into getting a Sidewinder Bobbin Winder as an auxiliary for winding the bobbins, which would be less expensive than the repair.
Posted on Mar 13, 2010
Bobbin winder not working
For ~$30, you can purchase a stand-alone bobbin winder (Sidewinder) that you can use to wind your bobbins. Saves wear-n-tear on your machine and you can wind bobbins without unthreading your machine. Just be sure to verify your bobbins are compatible with the Sidewinder.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Simplicity SideWinder Bobbin Winder Walmart com
Simplicity Sidewinder Bobbin Winder
Jul 18, 2017 | Sewing Machines
Singer Tradition - my bobbin winder has stopped winding so I have to wind thread on manually.
Check on a standalone bobbin winder called "Sidewinder." Make sure it is compatible with your bobbins--some bobbins won't work on the Sidewinder. If it is compatible, then for ~$30 you can wind all your bobbins. (I have one that is powered by battery or by electricity.)
Jul 16, 2017 | Singer Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Bobbin winder shaft wont spin
If you take it apart, you'll void the remaining warranty. The usual cause is not getting the door open completely and/or thread wrapped around the spindle.
You'll also want to take a look at: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=CS8150
Feb 11, 2014 | Brother CS-8150 Computerized Sewing...
Pfaff 2046 tension problems, needle breaks
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight--loosen off one letter or number till the stitch
looks normal
7.make sure that every thread guide is used when winding the
bobbin,, so that the bobbin will wind tightly, if this doesn't help,,
then it's possible that the bobbin winder needs adjustment,, it needs
to be taken to a sewing machine shop
Aug 15, 2012 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
I have a singer touch tronic sewing machine. I need to fill the bobbin and I cannot get it to work. where can I buy more bobbins that have already been filled to fit my machine
Has the bobbin winder worked in the past and now faulting. Or are you unsure on how to use it?
There is a manual for a Touchtronic 2000 here http://www.singerco.com/uploads/download/432_touchtronic.pdf there may be more than one model Touch Tronic so plse check the serial number plate on the side of your machine to establish the actual model number, usually near the power inlet plug. then search for the appropriate manual at http://www.singerco.com/accessories/instruction-manuals. This excerpt shows that you wind the bobbin insitu in the bobbin case.
I'm not a fan of prewound bobbins, far better to deal with the bobbin winder issue. Winding your own thread means you can get far better colour matching to the fabric, and ensure you've got quality thread on the machine, and same thread top and bottom. (I prefer a quality cotton wrapped polyester or a polyester thread, Guttermann, Molynecke or Sylko Supreme). All of these factors affect stitching quality and the finished appearance of a seam.
Did you know that you can buy a freestanding unit to wind bobbins? Link to this item is here. http://www.sewingpartsonline.com/universal-automatic-bobbin-winder.aspx You may well find that this is the better solution to winding bobbins for this machine as winding them inside the bobbin housing doesn't give you a lot of control over the way the thread feeds onto the bobbin.
Jun 27, 2011 | Sewing Machines
Bobbin winder will not wind
Mar 13, 2010 | Kenmore Sewing Machines
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
62 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
