Question about Western Digital Computers & Internet
I have a toshiba satellite a5100, would like to know which western digital hard drive I can use?
  • 3,960 Answers
If you will Google search the following, the WD drives that will work in this computer are shown: western digital 9.5mm 750GB SATA 5400RPM hard drive
Posted on Apr 19, 2015
SOURCE: Notebook does not recognize My Book / Western Digital hard drive
I have solved a similar problem to this. My laptop would not allow me to get to my WD Passport. The driver was fine and no errors were reported - it recognised the drive when I ran the hardware removal utility - I just couldn't see it from any of my windows applications and therefore couldn't get to any data.
The problem was that the passport was being designated as E:\ but my laptop already has a network drive mapped to E:\. When I am in the office the computer connects the network drive to E:/ and so my passport automatically picks the next available letter - F:\. Away from the office, the network drive is still buit shows as "disconnected network drive" and somehow the laptop gets confused into designating both the the passport and the disconnected network drive to the same letter. so the passport is not visible in My Computer.
To fix it I went to My Computer, right clicked on the disconnected network drive and select Disconnect from the options there. And hey presto the passport appeared!
You can see which letter your USB HDD is assigned in the device manager in XP. Right click on the device and go to the Volumes tab - click on Populate and the drive letter should be shown there. If that doesn't match what you see under that letter in My Computer it looks like you have a similar problem & so disconnecting whatever is there in My computer might help.
Posted on Jun 07, 2009
  • 22 Answers
SOURCE: my sata hard hard drive is not detected in linux
Check in your BIOS settings that SATA drives can be seen as "ATA"
Install Linux, and then , after everithing went OK, change BIOS to SATA again.
Posted on Aug 19, 2009
lserni
  • 466 Answers
SOURCE: 1tb Western Digital hard drive stopped working suddenly, no light
If the hard drive does not even turn on, then check its power supply. Maybe the power supply went bad; it should be a standard 12V 3.5A power supply.
Even if the power supply is working, chances are good that your data are still there, because the unit not turning on means that the internal enclosure, not the disk electronics, got messed up. It's unlikely that BOTH enclosure electronics AND disk electronics went south together, unless you got a lightning strike at short distance (less than 60 feet, say). You'll need to open the enclosure, extract the drive and connect it to another compatible enclosure (most USB/eSATA enclosures with the same EIDE or SATA connector as your WD will do) in order to override the fritzed enclosure electronics and connect directly to the hard disk. Once you do, your data will be there. If the disk crashed last time it turned on, maybe you'll need to run disk checker and expect to lose a file or two.
On the other hand, if the drive does turn on when powered, and the PC "just" doesn't see it, chances are proportionately bad for your data: you'll need to send the disk to a data recovery service, which can be quite costly.
Posted on Nov 03, 2009
Testimonial: "Great help, thanks!"
SOURCE: Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Posted on Nov 18, 2009
  • 163 Answers
SOURCE: My western digital Passport 320Gb usb drive is not detected
U need to update windows XP , USB drivers will be installed
Posted on Dec 29, 2009
My toshiba satellite L675d error 10-f12-0003
You may have a bad hard drive. If you are able to log into Windows, run Western Digital Data Lifeguard Diagnostic software.
1. Download Data lifeguard:
Hard drive analysis software
2. Install the software and run an extended test on your main partition.
If the test fails, then your hard drive is bad.1. Purchase a new hard drive from a local Best Buy or other2. If you don't have the original restore CDs, order them from Toshiba
Best regards,abdielcomputer repair plantation
Nov 17, 2011 | Toshiba Satellite Computers & Internet
While trying to install PATA 250GB HD (XP Pro) only 130GB recognized. Upgraded BIOS to v1.4 (latest) and assured by Toshiba that this would enable computer to handle 250GB. No such luck. Accessed BIOS...
According to the detailed specs on that model, it came with a 60GB ATA-5 EIDI hard drive. therefore, you can use any ATA compatible (ATA-5, ATA-6 or ATA-100) EIDE/IDE drive that has jumpers enabling you to configure the drive as "Master". Western Digital Blue Scorpio and Seagate Momentus lines both have models that will fit the bill. You can find those drives at your neighborhood BestBuy or Staples pretty easily. I don't know if the A25 BIOS supports 48-bit logical block addressing (LBA), in spite of what toshiba says, If it only supports 24-bit LBA the maximum drive size is 137GB. If it supports 48-bit LBA then you can go as high as you can find drives available; usually 500GB. I suspect that it supports 48-bit LBA because various online vendors list up to 250GB drives for that model. The most important thing about the drive, though, is that it MUST be jumperable as 'master'. A cable select only drive won't work. Both the Western Digital and Seagate EIDE models have jumpers. hope this helps but if you need anything else just ask:)
Jul 31, 2011 | Toshiba Satellite A25-S279 Notebook
I have a Toshiba A45-S121 laptop. I upgraded my hard drive from a 40GB hard drive to a 320GB Western Digital. Loaded Windows XP and formated drive in FPTS format. The computer rebooted to the hard drive...
Best possible solution put back your 40GB and try to get an external casing for your 320GB to see if it works.And try windows on NTFS instead of FPTS, so reformat your 320GB and install the Windows XP again.
I hope this solution is helpful.
Sep 26, 2010 | Toshiba Satellite A45-S121 Notebook
It is taking forever to use the recovery DVD to intall programs an a brand new Western Digital Scorpio 250 GB hard drive I bought for my Toshiba M35X-S114. BIOS doesn't detect the hard drive which is...
If it's a 250GB, the recovery DVD needs to format this drive (insofar as I know, Toshiba's recovery disks never uses quick format) - so .... yeah! It'll take a couple of hours just to prep the hard drive before the actual recovery imaging begins, and that's assuming that the hard drive formatted without errors.
If the hard drive has errors (bad sectors), it really could stretch out the total time. I've done a recovery on a hard drive that contained 100MB worth of bad sectors and it took an entire two days to put an image on it. Why'd I do it? I justed wanted to know how long it was gonna take...
Jul 27, 2010 | Toshiba Satellite M35X-S114 Notebook
The hard drive died, can I install Western Digital Scorpio Hard Drive - 120GB - 5400rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal (WD1200BEVE) to replace it
You should definitely try out if it fits inside the bay first.
The original drive in the M55-S135 has a height of 8mm and the WD1200BEVE is 9.3mm. This is not a big difference and may pose no problem, but you would like to have all covers close properly later, I assume.
Other than the slightly larger physical dimensions, the drive should be fully compatible with the laptop.
Feb 12, 2010 | Toshiba Satellite M55-S135 Notebook
I purchased a Western Digital EIDE 320GB hard to replace existing Toshiba 100GB hard drive. I cloned the old hard drive using Acronis software from Western Digital and when I placed the new hard drive in...
I have the same problem with my laptop. Here is my understanding of the problem.
Many laptops have a BIOS limit of 128GB hard drive capacity.
Try to find the latest BIOS available for the laptop, and see if it supports 48-bit LBA addressing of the hard drive.
If the BIOS only supports 24-bit LBA addressing, there are tools to restrict the size of the drive.
DISCLAIMER: I have read of Dynamic Drive Overlay (or Drive Dynamic Overlay) software, which is supposed to allow for the use of larger drives. I have not used one, so I do not know how well they work. I am sure they slow down access and, from what I have read, they do not work with Vista or Windows 7.
Dec 04, 2009 | Toshiba Satellite A75-S2762 Notebook
Western digital usb hard drive doesn't work with windows vista
Windows Vista is still playing catch up with compatabilty of devices.
Makes you wonder why you left XP doesnt it? i do this for a living, and i will not touch Vista for a few years yet, while they work the bugs out.
Jan 19, 2009 | Western Digital Computers & Internet
Compatible Hard Drive to replace one in Toshiba A100 Satellite
ahah..well..there are tons of those online. Just make certain that the connectors are compatible, since there is no one standard for connectivity.
Mar 02, 2008 | Western Digital WDG1C2500N MyBook Premium...
Computers & Internet Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
