Question about Nordic Track NordicTrack COMMERCIAL 1750 Treadmill
When I turn the unit on it makes a start up sound, there is nothing on the screen.11 and 12 mph buttons have not been working as well lately Red light is on motherboard when unit is turned on. HELP!!
A lot of wear has been put on treadmill as most of work is done between 10-12mph and over 100km/week.
  • 3 Answers
SOURCE: Buttons Froze during workout, now none of them work
It sounds like you just need some calibration. To calibrate incline, turn power on press press any incline buttons, as the incline try to change unplug the key. Now re-nsert key and incline will self calibrate,
Posted on Sep 02, 2009
  • 218 Answers
SOURCE: Treadmill lights up and goes off
Check the main harness running up to the console through the leg. unplug it and use a volt meter to test the red and black wires. You should have 9-12 vdc if you do and the console is not lighting check that the safety key is in place. If it is and it is still not coming on the console is malfunctioning and would need replaced. If there is no voltage coming through the harness then you will need to check the harness for continuity. If harness tests ok then the controller is malfunctioning and would need replaced.
Posted on Aug 11, 2010
SOURCE: When I turn on the
First of all you need a Surge protector, you can get one from Nordictrack.com, it is on sale. Secondly, unplug the treadmill and leave it unplugged for at least 24 hours. Before you plug it back again, make sure you already have a surge protector on your outlet. Also make sure Trreadmill is the only load on this circuit. Plug it and try again. I had the same problem, and mine works this way. Some times, with dilrty power, the bit get set and the bottons stop working. Good Luck!
Posted on Jan 03, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a C2155.
http://www.youtube.com/watch?v=E-q-uS4t6so
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet.
Do not use an extension cord.
    • 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
    • 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Watch this videos:
Posted on Nov 09, 2011
ercupa190
  • 12223 Answers
SOURCE: NordicTrack Treadmill A2050, Will not work or turn on.
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
Posted on Sep 20, 2012
When I push the power button....nothing but a poping sound.
It seems that your unit has had a major malfunction and some parts have been destroyed, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Televison & Video
Unit makes sounds but no display
Hi
If unit is as per pic I assume it has external antennae. Ensure the multi pin plug is secure in the rear of the unit and also use a fully charged 12 volt battery, Has it been working before?? Usually a rear plug problem. How old is unit. Just had a another thought, check that the polarity is correct, ie pos wire to RED (Pos) on battery. Very polarity sensitive.
Cheers cbacer
Aug 12, 2009 | Garmin GPSMAP 178C GPS Receiver
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Screen doesnt turn on
try selecting the dvd or tv modes ... if that doesn't help , reset the system and start all over.
Nov 10, 2008 | Jensen VM9510 Car DVD Player
Blue buttons (quickplay/sound/dvd controls) won't work
Mine did that as well then after rebooting started working??
Aug 16, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Nordic Track NordicTrack COMMERCIAL 1750 Treadmill Logo
116 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
