Question about Evinrude / Johnson 135-150-175-200 HP 60deg V6 2006 E-TEC Motor Cover Blue
1996 Evinrude 140hp started but ran only for about 10mins.
Wlll start on ether or pumping the bulb primer, but will only sputter. tried external tank but same thing. Is it the fuel pump?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Evinrude / J... Master
  • 1,190 Answers
Try removing the feed pipe off the fuel pump to the carbs and start the engine , put a pipe on the pump into a container and see if its pumping ! ?
Posted on Apr 26, 2015
1996 140hp evinrude started but stalled. will not restart
Has it been sitting up all winter? If so, you might need to drain fuel from the carb and replace the filter. It sounds like a fuel problem to me.
Apr 19, 2015 | Cars & Trucks
Engine stalled after about 10mins running will not restart.
check to see of the fuel pump is pumping gas and that gas is getting to the engine.
I have a 1988 30 hp.evinrude that starts and runs fine till i reach 3/4 throttle,then it will die.ant suggestions?
Fuel line could be sucking air.check breather not blocked on fuel tank.if fuel bulb sucks flat,means blockage btwn bulb and tank.have you tried priming motor while running at full throttle.could also be dirty carb
Jul 15, 2014 | Boating
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Stihl chainsaw primer bulb will not fill. Puts pressure in fuel tank
try switching the tubes on the back of the primer bulb
Nov 12, 2013 | Stihl Garden
Evinrude 120 vro outboard floods easily on startup , could spark plugs be wrong type
No,check vro fuel pump diaphragm.if primer bulb doesn't get hard when priming is a sign of needle and seat not sealing or a hole in fuel pump diaphragm.
Sep 08, 2013 | Sierra International 18-4310 Marine...
1996 mecury outboard, was running fine & just cut off, later it started & ran fine then when i shut off it would not start ? When I returned home i hooked the water hose to it , it started up right...
I don't know what horsepower the motor is, but if you are using an external fuel tank with the hose and primer bulb, then I would look at the bulb as being defective. I have an old 7.5 horse Sears motor and had a similar problem. I could get it to start but not stay running and the problem was in the primer bulb. It would shut my gas flow off. I replaced the hose and bulb on the tank and it resolved my issue. Hope this helped and best wishes.
Aug 02, 2009 | Boating
Primer bulb won't re-fill.
Not sure about your particular set-up, but there is usually two fuel lines running from the fuel tank. One goes to the carb and the other goes on a fitting on back of the primer bulb. The primer bulb will have a second fitting with a line going to carb. Sounds like either a clogged or leaking fuel line to me. Hope this helps and good luck.
Jul 11, 2009 | Garden
Evinrude / Johnson 135-150-175-200 HP 60deg V6 2006 E-TEC Motor Cover Blue Logo
515 people viewed this question
Top Evinrude / Johnson Boating Experts
ray gallant
Tom Hensel
Level 1 Expert
Fabrice Wolters
Are you an Evinrude / Johnson Boating Expert? Answer questions, earn points and help others
