Question about Frigidaire Washing Machines
On my Frigidaire Affinity 3.26 Cu. Ft. Front Load Washer I have power to the main control board. there are no LED lights at all on the front of the machine. I see one fried resister.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
Repair clinic dot com will help
Posted on Apr 20, 2015
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
How do I correct an E53 error code?
I appreciate your post, Allan!
From my understanding your Frigidaire washer is displaying an error code of "E53". An "E53" stands for low voltage to the speed control board. This could be a possible problem with your wiring harness between the motor control board and speed control board or the speed control board. I would recommend resetting your washer in case it is a miscommunication issue. To reset your washer you would need to disconnect power from it for at least ten minutes. If that does not correct your problem you may need to have a professional technician out for proper diagnosis and repair. I hope this is helpful information. -Matt
Jun 11, 2015 | Frigidaire FAFS4272LW Affinity 3.81 Cu....
How to disassemble atf6000fs?
Hey friend, I appreciate your for the post!
I understand you are trying to disassemble your Frigidaire washer, ATF6000FS. I have researched your error code "E90" and that seems to be an issue with your main control board or user interface board. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
Aug 07, 2014 | Frigidaire ATF6000FS Affinity 3.5 Cu. Ft....
My front load affinity will not start, says pause
Hello friend, thank you for your post!
I see that your Frigidaire washer, FAFW3517KW, is constantly showing you pause, when you press start it flashes the pause again, and that the door lock light does not come on. You could be seeing a couple of different possible reasons this is happening such as your control panel, door lock assembly, or door switch. Since it could be any of the underlying issues I would recommend having a professional come out to the home and repair the washer. -Matt
Aug 02, 2014 | Frigidaire Affinity FAFW3517KW 3.5 Cu. Ft....
Frigidaire Affinity Front Loader Washer
Check if there is any gap or if the bearing are worn on the agitator, check by pushing the agitator for any play. If so the bearings must be replaced,
Sep 26, 2012 | Frigidaire Affinity FAFW3511KW 3.5 Cu. Ft....
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing Machines Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
