Wont spin or drain water - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 43,020 Answers
Either the timer has failed or the pump might be plugged and not letting water through if full of water they will not spin
Posted on Apr 19, 2015
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
My machine wont drain the water or go to the spin
Drain Vlve command no activated. Or The valve is faulty. Check wiring also.
Mar 28, 2010 | Indesit W 123 Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Water wont drain and it wont go into the spin
if it is'nt making anny sound at all in spin its probly the lid switch
Dec 08, 2009 | Magic Chef Washing Machines
ALL FUNCTIONS OF WASH CYCLE WORK EXCEPT WATER WONT DRAIN AND SPIN CYCLE WONT WORK,
Pump is blocked or shot
Pressure switch made telling the machine it is full of water hence no spin.
Drop hose into bucket to drain the water off and the machine should spin, you may be better dragging the washer to an outside door and let all of the water run away at once .
Make sure that the drain hose is unclipped from the back of the machine so that the bottom of the hose is as low as you can get it
Jun 25, 2009 | Roper RAS8445KQ Top Load Washer
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Wont drain or spin is lock up
does not spin all water out, towels are still wet, not overloading, could it be the timer?
Mar 01, 2009 | Estate ETW4400VQ Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
