Question about Zanussi Washing Machines
I have an old Zanussi Aquaplus washing machine and the belt has come off. How do I put it back on as the back can not screw off. Please help.
    Top Expert:
  • Zanussi Master
  • 52,086 Answers
Then check the top to see if it tilts back sounds like you should call a service tech tho
Posted on Apr 19, 2015
  • 641 Answers
SOURCE: how to fit drive belt to zanussi washing machine
Does it a new belt or the existing one ?
Posted on Sep 04, 2007
SOURCE: zanussi washing machine drum will not go round at all
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
Posted on Apr 23, 2008
kjmac
  • 97 Answers
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
Posted on Jul 28, 2008
SOURCE: zanussi aquacycle 1000 washing machine spin problem
My zanussi aquacycle 1110 sounds like it is about to take off when it goes onto a spin cycle. Does anyone know what it could be? The big black spings are still in place inside the washer that hold the drum. It also rattles more than normal as well. Thankyou
Posted on Jan 12, 2010
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
Zanussi FJ1214 Washing Machine won't agitate but spins
Sounds like gearbox or check if a belt has came off or slipping underneath.
Nov 01, 2014 | Zanussi Washing Machines
Access motor belt zanussi aquacycle 1000
There is usually a hatch at the back of the washing machine.
Mar 17, 2014 | Washing Machines
Left screws in the back of new Zanussi washing now it wont spin
It must have broken some plastic off inside or may have jammed the belt mechanism. Check the belt and suspension/mounting.
Jan 16, 2014 | Zanussi Washing Machines
What is the easy way to fit a drive belt on to a zanussi fla1oo1w washing machine
Here are my general notes for broken or slipping belts and includes a comment on motors which you presumably can ignore. I hope they help you ;-0)
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished.
Hope this is your problem solved.
Good luck,
John C
Feb 23, 2011 | Zanussi FLA1001W Front Load Washer
Cannot remove rear panel of Zanussi FJR1454 W
At the bottom on eacvh side there is a small round plastic plug which is hiding the other screws.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Jan 18, 2009 | Zanussi F1045W Front Load Washer
My door handle on my zanussi fls 1183w washing machine has broken and ive bought a new handle but dont know how to get old one out can you help please
normally on zanussi doors they have 5 or 6 screws around the edge on the inside of the door if you try to undo them and take apart the door the handle should come out be carefull not to drop the glass
Nov 11, 2008 | Zanussi Washing Machines
Zanussi zwf 1231 w front load washing machine
all connections to the zanussi modules are plug and socket and are keyed so you can't put them in the wrong place
Jul 05, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine drum will not go round at all
Apr 08, 2008 | Zanussi ZWF1430W Front Load Washer
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
