Question about Haier Heating & Cooling
My Haier window AC suddenly stopped working. The display shows an e1 error code.
I have tried cleaning the filter, unplugging/plugging the unit, held the power button to try to reset, and pushed each button multiple times to see if a button is stuck. I don't have the remote. I have also read the manual and there is no reference made to the error.
    Top Expert:
  • Haier Master
  • 51,545 Answers
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
Jul 23, 2012 | Haier HWR08XC7 Air Conditioner
E1 shows and i unplug the unit and it will run for about 2mins and shut down with e1 showing
The E1 error code indicates that the air intake filter is dirty or clogged and needs to be removed and cleaned. Turn the unit OFF & unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, can damage the unit.
Hope this helped you & thanks for choosing FixYa.
Sep 20, 2011 | Haier Heating & Cooling
My ac is showing an E1 code. what can be done to solve this problem?
Unfortunately, there's not much you can do. The E1 error code indicates a sensor shutdown. However, you can try turning the unit OFF & unplug it for 15 minute. Then plug it back in and turn it ON. If the electronics reset and reverted back to the original factory setting, you can set the controls as you like.
If you continue to get the E1 error code,, contact Haier Customer Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Haier ESA3125 Wall/Window Air Conditioner
MY WINDOW UNIT JUST STOPPED WORKING AND NOW IT IS READING E1. HOW DO I GET IT TO WORK AGAIN?
E1-Automatic filter clean reminder.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
Displays "E1" and resetting the
Aug 08, 2011 | Haier HWR24VC3 24,000 24000 BTU Air...
E1 error code on air conditioner
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
Heating & Cooling Logo
369 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
