Question about GE Dishwashers
No power lights on ge dishwassher. Replaced control board, clwa
Clean button flashing but DW would not start. Replaced main control board Clean button still flashed, no other keys worked. Started DW in service mode, powered off/on and DW responded with test noises, yet no buttons produced a result. Powered off/on, no buttons lit and can not start in service mode. Ideas?
SOURCE: "3 second" light flashing
The 3 second flashing light is a lock that locks out all other functions. To disable, depress the 3 second light for 3 seconds and all the functions will be released. This feature is to use to keep little kids from starting the appliance.
Posted on Jul 04, 2007
  • 9 Answers
SOURCE: Lights are on, but wont start
The water pump can hum and still have a defective coil.
Posted on Aug 31, 2008
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
SOURCE: i have a kenmore dishwasher mode 665.16032402
I was able to reset it using this procedure:
1. Crack the dook open
2. Within 3 seconds, press these buttons in this squence: Hi Temp Wash, Heated dry, Hi Temp Wash, Heated Dry
3. Close door
4. Press Cancel
That should clear the Blinking LED. It appears this is a common problem. The worst thing is they charge to come out for this.
Posted on Jan 13, 2010
rylee_smith
  • 8619 Answers
SOURCE: clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
DW (top drawer) will not start.Green light comes on when pushed to start but after 1-2 minutes, DW starts beeping and start button light turns red.
Turn the mains power off and back on after a little delay. If no change, some sensor in the drawer is faulty - most likely the drawer close sensor as it is telling the controller the drawer is not closed.
Mar 23, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
GE gld5708vbb flashing lights locked controls
It is possible that since the neutral was bad it could have made a surge on the power and caused the processor controller to fail. It is also important that this must be confirmed to be corrected by checking with a larger load like a heater being switched on and not causing any voltage drop. If so the line is clear. Also make sure that the ground - Earth- is also intact.
The program has reset because of an error and it must be confirmed to be within or outside the washer. So remove plug and test this terminal with a large load test to confirm that the outlet is OK.
If so check the panel connections or is best to refer back to the dealer as the replaced panel will have a warranty.
Please take second opinion before the board is removed.
Jun 28, 2012 | GE 24 In. Black Built-In Dishwasher -...
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Sep 05, 2011 | Dishwashers
No display on temp controls and both frig and freezers are warm. i don't here the motor running at all. this happened after we had a power flash do to weather.
your main board in the back of the unit is bad and needs replacing,if you recently replaced a burned out light bulb in the freezer and now they strobe rapidly this is another good sign its this board the new board is a G.E. # WR55X10942
Aug 22, 2011 | GE PFS22SBSSS Stainless Steel French Door...
Replaced the control board of my quiet partner
clean light flashing is a power interuption between the heater and the control often its is actually the door switches from not closing the door evenly but a chance that the heater is bad.also if you replace the main ccu it should have a software update that buypasses the fault and a good start wouldd be to reverse the door switch and test your heater for ohm values you want it to ohm out
Jun 02, 2010 | Dishwashers
Allan Dishwasher won't start. Clean light keeps flashing. I have tried cancelling a couple of times, and it goes through a 2 minute process and goes right back to the flashing clean light and not allowing...
Turn off the power at the breaker to the DW and wait 15 seconds and then turn it back on and see if problem is fixed. Reboots the controller.
Aug 20, 2009 | Dishwashers
GE Dishwasher shows no power indicators
Lightening can damage the electronic components on the main control board, and they must be replaced. Most boards cost between $150 - $200 plus labor
Aug 13, 2009 | GE 24 in. GLD5560LSS Stainless Steel...
Sears Kenmore model# 665-16022401 Serial# FS0304946 - Clean Light Blinking
THE HUMMING NOISE THAT YOU ARE HEARING IS THE ELECTRONIC DRAIN MTR ACTIVATING BUT YOU HAVE NO WATER IN THE SYS. SO IT SOUND LOUDER AND DIFFERENT THE HUMMING IS THE LESS OF YOUR WORRIES THAT IS NORMAL BUT WHAT IS NOT NORMAL IS THE CLEAN LIGHT FLASHING IF IT FLASHES 7 TIMES THEN PAUSES YOU HAVEA BAD PROCESSING BOARD AND ALSO A HEATER ON SOME OF THE KM MODELS THE CONTROL BOARD AND HEATER IS SOLD AS A KIT. TO VERIFY THAT THIS IS THE CASE GO TO WWW.SEARSPARTS.COM . BUT FIRST ALSO CHECK TO SEE IF YOU HAVE A BURNT WIRE AT THE HEATER ASSEMBLY WHICH WOULD REQUIRE PULLING THE DW OUT. GOOD LUCK
Mar 12, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
GE EMO3000 Over the oven Microwave
Do you know if the fuse blew again? You may have a problem with the powers supply section that powers the main board. The main board controls the display and receives input commands from the keypad.
Please let me know if I can be of further assistance to you.
- Jim
Feb 24, 2008 | GE EMO3000 Microwave Oven
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
