Question about Miele Vacuums
Red warning light miele vacuum
Vacuum stopped working. red warning light on. i checked the filters, clogs, everything.
reddevil6
  • 1673 Answers
SOURCE: stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Posted on Jan 17, 2008
reddevil6
  • 1673 Answers
SOURCE: Miele vacuum loses power automatically
Could have a problem with the motor, there also is a speed control circuit board mounted by the motor that may be starting to go bad.
Posted on Jun 17, 2008
SOURCE: Miele S758 stops working for no reason
The problem on mine was as described by others. Miele s758 stops for no apparent reason. The first time it happened I had the hose assembly replaced under warranty. Two years later, same problem. I have found that contacts at BOTH ends of the hose were intermittent. I dismantled both ends, extracted both sets of contacts, immersed both sets of slip-rings in methylated spirits and cleaned all the black gunk away. The three PCB mounted contacts were similarly cleaned, retensioned and lubricated with Electrolube. After re-assembly the problem has disappeared. I imagine a repeat procedure will be required in a couple of years.
CAUTION: The procedure is a bit tricky, so unless you know what you are doing, it would be preferable to have it done by someone who does. It is worth fixing as the replacement assembly is $AUD400.
GeeJayL
Posted on May 14, 2009
tooltech75
  • 80 Answers
SOURCE: Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Posted on Oct 07, 2009
SOURCE: miele silver moon vacuum just quit
Usually this is a problem with the electric circuits in the hose / handle.
Posted on Feb 01, 2010
The red filter light will not reset after replacing the filter on my Miele S5980
Hi There, I actually did a repair on this problem only a couple of weeks ago. The problem could be that the small lever that pushes on the reset button on the circuit board is bent or broken. The little button costs about $10 from memory and certainly a whole lot cheaper than the board itself which is $234. Just to clarify in my case there was nothing wrong with the board, I was able to manually push the reset switch on the board and replace the tiny lever and problem was solved.
Apr 17, 2013 | Miele S5980 Capricorn /SEB 217
I have a Miele turbo plus solaris and the red warning light is on. This prevents the vacuum from working. I have changed the bag so I am not sure what to do?
I had this problem with a different model. It's caused by a thermal cutout switch in the motor. My problem was a result of a filter being removed and the bag not seated correctly, hence dirt got into the motor and clogged the turbine, reducing airflow through the motor and causing the over heating.
If your motor runs at all, you probably have a blockage. Replace the filter inside the bag compartment just before the motor vent. Check the hose isn't blocked. Check the exit air filter.
If your turbine is clogged, it's a big disassembly job best done by a professional. If you really want to know how to cure it and feel you can tackle it yourself, email me. alan_at_alanjohnston_dot_com.
If your motor doesn't run at all and the light just quietly comes on, you have a break somewhere in the thermal protection circuit, either in the wiring (unlikely) or inside the circuitry buried inside the motor itself. I had an open on the thermal switch where the combination of heat and vibration deoldered the thermal switch from its board.
Hope this helps.
Alan
May 21, 2010 | Vacuums
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
Warning light on, vacuum will not turn on
Your machine is clogged ... probably in the hose.
ASSURE the air path is clear and the filters are clean before yhou proceed.
Let me know how you make out on this.
a
Sep 23, 2009 | Miele S558 Red Velvet Bagged Canister...
Miele Silver Moon 558 displays red triangle and won't start.
Meile vacuums are great when they work but they are expensive when they dont work you have to pay out of the rear end to fix them if it isnt something like a clogged air filter
Feb 27, 2009 | Miele s558 Silver Moon Vacuum
Miele white star canister vacuum - won't turn on, but isn't clogged
Miele S251i Plus Bagged Canister Vacuum
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Apr 18, 2008 | Miele S251i Plus Bagged Canister Vacuum
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Red light comes on and switches itself off
You may have to take some screws out, save them so you can put them all back. Check the impeller and cavity. If rocks and/or coins etc got sucked up the blades could be broken, this causes it to run out-of-balance. Debris can also get in there. Long stringy objects like hair, grass, straw, rug fibers, etc often gets wound the impeller shaft. This causes friction and binding, making it work harder.
Jan 29, 2008 | Miele Cat & Dog 326i Bagged Canister...
Stopped working - warning light on
Dec 05, 2007 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
