Question about Select Health & Beauty
Were is the reset button on a jazzy select 1113?
    Master:
  • Select Master
  • 401 Answers
Right side of meter in the back of the base.(behind the seat). Unless there is another problem like the freewheel levers are not facing the right way, or the Joystick is flashing lights at you this is a code. Telling us what is wrong.
Strege Mobility
Posted on Apr 29, 2016
  • 38 Answers
SOURCE: We have a Jazzy 1113
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
Posted on Dec 30, 2008
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
  • 32 Answers
SOURCE: Controller Fault Error 1113 Programmable Controller
yes
  • 32 Answers
SOURCE: Jazzy 1113 batteries go dead quickly even new
it is not uncommon for some of the new batteries available today to be defective...load test them
Posted on Apr 20, 2009
  • 175 Answers
SOURCE: jazzy 1113 will not charge,
Most likely your charge isn't charging properly. You need a multimeter to test the voltage at the joystick. In the 3-pin femal connector measure the voltage across the two horizontal terminals. It should read about 24 volts. Now plug it into the charger and see if the voltage increases, if not, charger needs to be replaced. You can get one that plugs into the joystick on ebay a lot cheaper than going to the mfgr. about $50.00 or so. Even if the lights are blinking, it may not be putting out sufficient voltage to bring the batteries up.
Posted on Jan 08, 2010
I NEED THE CODES
Go to Pride Mobility website/ http://www.pridemobility.com/jazzy/
and get manual for Jazzy 1113 it is found on page 31 but manual for jazzy113ats doesnt have codes. Good luck.
May 12, 2014 | Pride Jazzy 1113 ATS Indoor Power...
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
Jun 17, 2012 | Pride Jazzy 1113 ATS Indoor Power...
The jazzy 1113 will not start, when you press the power button the speed light comes on gets full and then turns back off
How old are the batteries? If you've had them for a few years it might be time to change them. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1113 http://www.replacementupsbattery.com/UB12350-NB.html
Nov 08, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 ats won't start
Nov 04, 2010 | Pride Jazzy 1113 Power Chair
I just put new batteries in my Jazzy 1113 and the lights on the controller just blink and will not come on. Is there any thing else I need to check?
Check this website to find the type of controller your scooter has. The number of blinking lights will give you an idea as to the the problem is. You may need to reset the system after replacing the batteries. Check your manual for troubleshooting diagnostic codes.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Oct 10, 2010 | Pride Jazzy 1113 Power Chair
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Health & Beauty Logo
98 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
