Question about Boating
How to wire tactometer - Boating
    New Friend:
  • 17 Answers
If you have an outboard you need to locate three wires which are in the control box or in the ignition harness.
1. Gray wire. This is what drives the Tachometer signal. It runs off the charging coils.
2. The Purple wire. This is Ignition on. When you turn on the ignition it is energized
3. Ground. You need a ground also can be found on the key switch.
Connect the Gray wire to "S" on the Tach. Connect the Purple wire to "I" on the Tach. Connect the ground to "G" . The only other thing to do is hook up the light and that can be done by running a wire from the running light switch to the Light on the Tach. The light wires are light blue
Hope that helps.
Posted on Apr 20, 2015
  • 4,500 Answers
It is a long time since I wired a tacho to anything. Engines with conventional ignition and even engines with electronic ignition fitted (with a separate ignition coil) are relatively straightforward but you should obtain fitting instructions from the manufacturer of the meter or from the manufacturer of the engine where the engine is managed by an ECU. There might be a dedicated output for a tachometer.
It is important not to make a potentially expensive or inconvenient mistake unless you also like rowing.
Posted on Apr 19, 2015
My keys have been stuck in my ignition for over a year. my car has been cutting off while driving and the tactometer completely dropping and steering wheel locking up. i have replaced the crank shaft...
ignition lock cylinder. change the ignition lock cylinder. it controls the positions of the ignition switch, which control whether or not the engine starts or stops.
Sep 17, 2013 | Cars & Trucks
I have a 1995 nissan altima that has major issues. it has been cutting off while driving down the road. the tactometer completely drops and steering wheel locks up. it usually starts back up after 5 to 10...
I would try changing the igniter in the distributor, or the whole distributor. Make sure there is no oil getting into it. You may need a gasket under the distributor. It seems to be common that the gasket leaks and the igniter fails.
Sep 13, 2013 | 1995 Nissan Altima
Color code wiring for radio
1996 Chevrolet Suburban Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Ignition Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Oct 11, 2012 | 1996 Chevrolet Suburban
GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Sep 25, 2010 | UPM Programmable Wall Switch Timer
My speedometer and tactometer do not work. Mileage stuck on 110000 miles. Only works in the warm weather...why
They are fluid damped guages, but the mileage should still increase. Sounds like a faulty instrument cluster.
If you choose to buy one from a scrapped vehicle, then you should buy one with a lower mileage than your current vehicle. The mileage will flash until reset by a dealer (or someone with a suitable computer) and the higher figure will be the figure that it is reset to!
Jan 09, 2010 | 2002 Land Rover Discovery Series II
2005 FORD F65O- SPEEDOMETER, TACTOMETER NOT WORKING CAN YOU HELP?
This is fairly common particularly on the 05 Mustang models. The problem is failing stepper motors on the instrument cluster circuit board. Check out this page for a fix for it - 05 Mustang speedometer fix
Dec 03, 2009 | 2005 Ford Mustang
My speedometer is not working and my tactometer is not either
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Yukon instrument cluster repair
Nov 22, 2009 | 2005 GMC Yukon Denali
While driving car all of the electronic devices shut down and car will not move even though the engine remains running.
This may not help you out any i'm no mechanic but i had the same problem with my Honda about 6 or 7 years ago. While driving to a Honda shop to have it serviced the tactometer went dead, then the radio, and each device slowly shut down but then the engine on mine went dead as well. At the Honda shop they told us that it had to do with a computer that controls all of electronic devices. Anyway the reason why all of it shorted out was the result from using my emergency brake all the time. Somehow the main wire that controled all of the electronic devices shorted from the constant rubbing resulting from the emergency brake. Sorry i can't remember what it was that actually went out but maybe this could give you a starting point.
Aug 11, 2009 | 1995 Honda Accord
Can,t figure out how to wire it up to my 1995 jeep and would like to find out how to wire it up?
Dont know what model you have so here u go!
1995 Jeep Wrangler Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Red/White
Car Radio Switched 12V+ Wire: Purple/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Blue/Red
Car Radio Dimmer Wire: Red/Black
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Dash
Left Front Speaker Wire (+): Gray
Left Front Speaker Wire (-): Yellow
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Brown/Red
Rear Speakers Size: 4′
Rear Speakers Location: Rear Roof
Left Rear Speaker Wire (+): Gray/White
Left Rear Speaker Wire (-): Brown/White
Right Rear Speaker Wire (+): White/Black
Right Rear Speaker Wire (-): Brown
1995 Jeep Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Violet/White
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Switched 12V+ Wire: Red/Gray
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
window.google_render_ad();
Jun 03, 2009 | Pioneer DEH-P2000 CD Player
Boating Logo
101 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
